Author Topic: Oil level  (Read 15217 times)
MustangGT
Oil level
« on: July 05, 2015, 08:43:33 AM »
Hi guys
Quick question about amount of oil in my engine.
I have a 8qt pan and a 1qt System1 filter. Aftermarket Shelby block with dipstick tube and a stock dipstick.
Should I put 9qt in this engine? I just want to make sure I have the correct amount of oil in it and then scribe new markings on the dip stick if necessary.
Thanks.
Regards
Morten
Re: Oil level
« Reply #1 on: July 05, 2015, 09:24:29 AM »
I think 9 quarts might be too much, but I doubt it would hurt anything.  If it were me I'd use the marks on the stock dipstick tube as a guide.  No reason you can't run the oil at the stock level in your 8 quart pan.  I'd try 8 quarts, and see where you end up on the dipstick.  If you are at the stock level with 8 quarts, I'd just leave it there.
MustangGT
Re: Oil level
« Reply #2 on: July 05, 2015, 09:34:59 AM »
Thanks for answering Jay.
The problem is that I don't know of the stock marks are in the right place since I am running a Shelby block with the dip stick tube that came with it. The dip stick tube is shorter than on the stock 390 that came out of the car so I am not sure the dip stick itself sits at the correct hight?
I am trying to find a reference oil level :)
Re: Oil level
« Reply #3 on: July 05, 2015, 10:21:36 AM »
When working with a new oil pan and dipstick with unknown levels, it is always a good idea to pre-fill the oil filter, and add 5 quarts.  Then I pre-oil the engine by spinning the oil pump to make sure all the rocker arms oil, and pushrods oil, etc., check for leaks, and then let sit for a couple of hours while I do other things.  I then check the dipstick for level, add 1 quart through either the valley, or valve cover, and let sit for a few minutes and recheck the dipstick.  If it reads, I scratch a mark for that level, add 1 more quart, repeat, until I have the desired number of quarts installed.  Never had a problem with low oil using this method whether it is a 7, 8, or 9 quart system.  Joe-JDC
MustangGT
Re: Oil level
« Reply #4 on: July 05, 2015, 10:36:24 AM »
I agree and I always prefill my filters too but what is the desired number of quarts in my system with a 8qt pan and 1qt filter?
Re: Oil level
« Reply #5 on: July 05, 2015, 10:45:03 AM »
The stock filter is about a quart, so I wouldn't consider the filter in your figuring.  The oil level in a stock 5 quart pan is 2.25" below the pan rail of the block.  There's a picture of an oil pan with the oil levels marked on page 234 of my book, if you happen to have a copy.  Maybe just mark the dipstick/tube combination that you have to hit that level?
MustangGT
Re: Oil level
« Reply #6 on: July 05, 2015, 11:09:57 AM »
I have your book, Jay.
I just had a look at page 234 and saw what you mean.
Engine is in a running car, just wondering if I have enough or too much oil in it. I guess I'll just drain it, fill 8 qts including prefilling of the filter, let it run for a few minutes, wait over night and mark the dip stick at that level. Should be pretty close then.
Re: Oil level
« Reply #7 on: July 05, 2015, 12:26:54 PM »
Who makes the pan?  I thought Canton's 8 quart pans were total "system" capacity including filter.  An email to whoever made it would give you their opinion
MustangGT
Re: Oil level
« Reply #8 on: July 05, 2015, 12:32:27 PM »
Pan is from Moroso. I'll shoot them an email and ask :)
Re: Oil level
« Reply #9 on: July 05, 2015, 12:49:33 PM »
I'm looking at my Moroso catalog right now. I'm guessing you have either the #20607 or #20608 oil pan. Interesting note on bottom of page: OIL PAN CAPACITIES DO NOT INCLUDE OIL FILTER CAPACITY. I would say it is a true 8 quarts in the pan + filter.
MustangGT
Re: Oil level
« Reply #10 on: July 05, 2015, 12:52:29 PM »
My pan is the 20608 with internal trap doors and baffles.
I have just sent them an email so it will be interesting to hear what they say :)
Re: Oil level
« Reply #11 on: July 05, 2015, 12:56:32 PM »
Hopefully their tech's answer confirms what is in the catalog. I hate when you ask several people and get several answers. I would say if they tell you different, I would start at 7 quarts in the pan plus filter and go from there. Easier to add more than take away. ;)
MustangGT
Re: Oil level
« Reply #12 on: July 05, 2015, 02:58:48 PM »
Yeah, lets hope he does :)
Re: Oil level
« Reply #13 on: July 05, 2015, 04:22:50 PM »
Is there a rule of thumb regarding oil height compared to the bottom of the block?
Such a rule of thumb might help with non-stock combinations and unknown dipstick markings.
paulie
MustangGT
Re: Oil level
« Reply #14 on: July 05, 2015, 04:26:12 PM »
paulie
Look at the posting Jay made earlier. 2.25" below pan rail
