Author Topic: Oil level  (Read 15220 times)
Re: Oil level
« Reply #15 on: July 05, 2015, 04:42:56 PM »
Is there a rule of thumb regarding oil height compared to the bottom of the block?
Such a rule of thumb might help with non-stock combinations and unknown dipstick markings.
paulie
Look at the posting Jay made earlier. 2.25" below pan rail
I didn't see Jay's earlier posting.  My mistake.  Is that figure the ideal though?
paulie
Re: Oil level
« Reply #16 on: July 05, 2015, 07:05:41 PM »
I did some measuring on this subject.
With the T pan you can put 8 quarts in the pan and 1 in the filter no problem.
9 in the pan if you really want.
Here is the level at different quarts. This is 6 in a stock pan.
Remember when the engine is running there is about 2 to 3 quarts out of the pan.
http://fepower.net/simplemachinesforum/index.php?topic=201.msg1303#msg1303
MustangGT
Re: Oil level
« Reply #17 on: July 06, 2015, 09:00:58 AM »
Thanks for your feedback guys.
Here is what tech support at Moroso answered: "Our stated capacities are always just the pan. So it would be 8, plus the filter."
So I guess 1qt in the filter before it goes on + 8qt in the pan, start it up, let it sit off for a good while and then pull the dipstick and make a mark will be fine then :)
