Author Topic: My FE Powered 1966 F100 "Project"  (Read 165979 times)
Re: My FE Powered 1966 F100 "Project"
« Reply #90 on: March 18, 2018, 08:19:05 PM »
That's nice!
wowens
« Reply #91 on: March 23, 2018, 07:06:36 AM »
That's nice!
Mr. Conley has again set the bar.
Extremely beautiful build.
Woody
TimeWarpF100
« Reply #92 on: March 27, 2018, 01:17:50 PM »
TimeWarpF100
« Reply #93 on: March 27, 2018, 01:18:49 PM »
427 Truck makes bangshift once again!  I stop by for my daily "fix" and was surprised to see it this morning.
https://bangshift.com/general-news/project-cars/bangshift-project-files-we-check-in-on-a-1966-ford-f-100-packing-a-427-side-oiler/
TimeWarpF100
« Reply #94 on: March 29, 2018, 06:01:55 PM »
Finally got truck moved into main shop where I can actually get at it. Not so cramped! Hoping to get back on it in morning . .
Any guesses to weight the way it sits? Also front rear bias. What will it weigh when done?
Goal was 3650 done but dont think I will get it that light. Would have needed Aluminum block and who knows what else.
« Last Edit: March 29, 2018, 06:05:13 PM by TimeWarpF100 »
james
« Reply #95 on: March 29, 2018, 08:06:26 PM »
My Boss 9 460 block 572 is being assembled as of last week. I have only one more item to order and that is the TD rockers. I'm going with the Boss 4500 Intake and a 4500 single dominator carb, 1050. https://i.imgur.com/g1YQTCz.jpg  Btw, the car is a 1966 mercury comet cyclone and it is in paint. I chose the Ford color Ruby Red Metallic.
« Last Edit: March 29, 2018, 08:11:57 PM by james »
TimeWarpF100
« Reply #96 on: March 30, 2018, 08:20:09 PM »
Cool! 1966 Cyclone my all time favorite looking car. How about pics?
TimeWarpF100
« Reply #97 on: March 30, 2018, 08:25:29 PM »
My last one. Owned it 16 yrs but had to give it up when I
Moved. 700hp pump gas BBF back in 1992. Sold car in 2004
james
« Reply #98 on: March 30, 2018, 09:30:37 PM »
Like I said the car is getting sanded for paint. I would like you advice on a couple of things. The following is a picture of the mustang 2 front end. How can I beef up the front of the frame for this motor? https://i.imgur.com/zArLs2s.jpg
Secondly, what kind of rear system would you recommend to get traction? Four link, 3 link, cal tracs etc. I definitely need to beef it up as well. I will also be installing a cage which should help. Thank You!  I do have this pic of the car.
« Last Edit: March 30, 2018, 09:37:09 PM by james »
TimeWarpF100
« Reply #99 on: March 30, 2018, 10:54:05 PM »
Very cool! With the upper apron supports, crossmember etc it should be pretty good as is. You could always add some 1 1/2” or so DOM tubing from firewall forward but don’t really think it’s needed. What’s intended use? You could also add a support bar in Engine bay across shock towers or from firewall area to shock towers to help stiffen it up.
TimeWarpF100
« Reply #100 on: March 30, 2018, 10:59:23 PM »
Truck as it sits is 3239 lbs! Guesstimate need to add
500lb to complete.
TimeWarpF100
« Reply #101 on: April 02, 2018, 09:41:16 PM »
Finally in a spot where I have room to work in it.
now trying to find proper spot for the Reservoir/pump for the fuel system and exactly how to run wires, best place to mount ignition box etc.
Hoping to have it fired for very first time within 2 weeks time.
« Reply #102 on: April 03, 2018, 02:16:31 PM »
First time I've seen one of those water controlled vacuum advance units. How exactly does that work, and how do you keep the water in there? 8)
That's cool you made Bangshift. The truck certainly deserves some coverage!
TimeWarpF100
« Reply #103 on: April 10, 2018, 02:46:00 PM »
Its actually a vacuum controlled oil pressure control unit operated by the pcm to keep the perfect Oil Pressure at any rpm. It plugs in in place of distributor. Its ran wireless back to the timing control unit that sits under dash. Therefor I have perfect oil pressure and perfect timing at any given RPM.
« Reply #104 on: April 10, 2018, 03:29:50 PM »
Aah Doug  ;D
