Author Topic: My FE Powered 1966 F100 "Project"  (Read 165718 times)
JamesonRacing
Re: My FE Powered 1966 F100 "Project"
« Reply #240 on: August 05, 2019, 09:23:14 AM »
Looks great!
What did you do with the I-beams and the king pins?
TimeWarpF100
« Reply #241 on: August 05, 2019, 10:52:39 AM »
Looks great!
Took them apart, cleaned off all surface rust then sprayed a satin clear on them
Replaced king pins & bushings.
« Reply #242 on: August 05, 2019, 01:58:17 PM »
I'm always amazed at how quickly you get work done.
TimeWarpF100
« Reply #243 on: September 11, 2019, 04:37:46 PM »
I was doing ok until now! Had 3 FE blocks at a local machine shop for some very basic work. Lets just say all 3 blocks are ruined beyond repair! Have never seen such incompetence in my lifetime. These were the last 3 blocks I had left too.
Shop mixed up the main bearing caps then attempted the align hone. Lets just say .009" out on caps at parting line!
The middle thrust bearing in cap will spin around like a "bearing" absolutely all the crush is GONE! AND they had told me a couple weeks and its now 6 months later and I have NOTHING but time and $ wasted.
TimeWarpF100
« Reply #244 on: September 11, 2019, 06:03:17 PM »
one of the rods and far from the worst. Did not check all but one if nut was just snugged there was a .088 gap on opposite side. Yes, 88 thou not 8.8.  Mains were angle cut the same way. If rod caps or main caps were put on a flat surface they would rock in both directions.
TimeWarpF100
« Reply #245 on: September 11, 2019, 06:17:01 PM »
Supposed to be reconditioned with ARP bolts. They had cranked nuts so tight there were more than one stud with stripped threads and all were way way over torqued. Total joke.
« Last Edit: September 11, 2019, 06:22:59 PM by TimeWarpF100 »
« Reply #246 on: September 11, 2019, 11:50:21 PM »
Unbelievable  :(
TimeWarpF100
« Reply #247 on: September 28, 2019, 01:48:49 AM »
Truck has been down going on 6 months. Got tired of waiting so had opportunity to buy a
Late model Crate Engine instead of the FE
450/510 version for less than cost of just a decent FE
Total bummer really.
Looks like the end of this thread
TimeWarpF100
« Reply #248 on: March 09, 2021, 04:54:36 PM »
fter 2 yrs of messing around trying to gather pieces for another 410 I decided to go the very basic route of .020 390 with good machine work and then drop it in the ‘66 F100 clone of my dads truck.
For something different going to mess with MPG and very low rpm build. Idle to 4000 rpm.
Zero deck, 9.0 comp, hone with deck plates, square deck etc. just got block, heads, balanced assy back from machine shop on Saturday.
Orange White truck that had 482 now has Raptor Crate Engine & 10 spd. It will be long distance cruiser.
Custom pistons too so I can get good ring pack.
Edit Add: For some reason would not allow photo's will try later.
« Last Edit: March 09, 2021, 04:58:16 PM by TimeWarpF100 »
TimeWarpF100
« Reply #249 on: March 09, 2021, 05:18:48 PM »
photo testing
winr1
« Reply #250 on: March 09, 2021, 10:08:12 PM »
Sorry bout your machine shop problems ... hard to find a competent shop now
What brand are the pistons if I may ask ??
Forgot... those heads are so clean ..... how is that done ??
Ricky.
« Last Edit: March 09, 2021, 10:09:47 PM by winr1 »
TimeWarpF100
« Reply #251 on: March 16, 2021, 11:01:28 PM »
Ricky.
Pistons are a custom from RaceTec
Heads cleaned with media then clean up cut.
TimeWarpF100
Re: newest projects
« Reply #252 on: April 10, 2021, 08:39:55 AM »
thought some may like to see a couple of my latest purchases. Tripped over them both. Ramp Truck and Camper in mind for them.
This truck is beyond rare and the only 1966 N series crew cab known to exist. This one is a N700 330 2v, 5 spd with a 2 spd diff
« Reply #253 on: April 10, 2021, 09:48:02 AM »
I’ve never seen one. That is beyond cool.
« Reply #254 on: April 10, 2021, 10:00:59 AM »
Agree!  That is going to be super awesome!  I didn't know such a thing existed  :D
