Author Topic: A Y block welded stroker crank  (Read 2064 times)
Royce
« on: May 15, 2026, 07:33:03 PM »
Since billet cranks run up to 5 k these days I am welding a steel 292 crank from 3.3 stroke to 3.75 with a 1.88
Bearing. Should be able to handle 550 horse
https://www.facebook.com/share/r/1Ba157ksg8/
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
mummert
Re: A Y block welded stroker crank
« Reply #1 on: May 18, 2026, 04:07:41 AM »
 Watch out for the oil hole.
Royce
« Reply #2 on: May 20, 2026, 09:25:42 AM »
I believe he welds and re-drills the oil hole if necessary.  This guy makes 7 inch Welded cranks for M Farmalls for pulling.    He is a former employee of Adney Brown and was recommended by him
1992 BMW V-12 5.0
Royce
« Reply #3 on: May 23, 2026, 09:16:56 AM »
Final results on Y Block welded stroker crank, 292 steel truck crank from 3.3 to 3.75 stroke with Honda journal.  Aprox 350 cubes
https://www.facebook.com/share/r/1DmHPAZg1G/
1992 BMW V-12 5.0
« Reply #4 on: May 23, 2026, 04:04:28 PM »
3.830 x 3.830 x  3.750 x 6.2832 = 345.63 ci, 3.860 x  3.860 x 3.750 x 6.2832 = 351.06 ci.  My '55 Thunderbird has a 345 Y in it as a driver.  Joe-JDC
hbstang
« Reply #5 on: June 06, 2026, 12:52:47 PM »
and if you needed a couple more counter weights like the billets,you could just weld them on.lol
