Member Projects
A Y block welded stroker crank
Topic: A Y block welded stroker crank (Read 1657 times)
Royce
May 15, 2026, 07:33:03 PM »
Since billet cranks run up to 5 k these days I am welding a steel 292 crank from 3.3 stroke to 3.75 with a 1.88
Bearing. Should be able to handle 550 horse
https://www.facebook.com/share/r/1Ba157ksg8/
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
Kaase Boss 547. 840 HP 698 Torque pump gas
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
mummert
Jr. Member
Re: A Y block welded stroker crank
Reply #1 on:
May 18, 2026, 04:07:41 AM »
Watch out for the oil hole.
Royce
Reply #2 on:
May 20, 2026, 09:25:42 AM »
I believe he welds and re-drills the oil hole if necessary. This guy makes 7 inch Welded cranks for M Farmalls for pulling. He is a former employee of Adney Brown and was recommended by him
1992 BMW V-12 5.0
Royce
Reply #3 on:
May 23, 2026, 09:16:56 AM »
Final results on Y Block welded stroker crank, 292 steel truck crank from 3.3 to 3.75 stroke with Honda journal. Aprox 350 cubes
https://www.facebook.com/share/r/1DmHPAZg1G/
1992 BMW V-12 5.0
Truth stands on its own merit.
Reply #4 on:
May 23, 2026, 04:04:28 PM »
3.830 x 3.830 x 3.750 x 6.2832 = 345.63 ci, 3.860 x 3.860 x 3.750 x 6.2832 = 351.06 ci. My '55 Thunderbird has a 345 Y in it as a driver. Joe-JDC
hbstang
Sr. Member
Reply #5 on:
June 06, 2026, 12:52:47 PM »
and if you needed a couple more counter weights like the billets,you could just weld them on.lol
Member Projects
