Author Topic: measuring compression height on sohc dome piston  (Read 10810 times)
hbstang
« on: August 20, 2025, 01:39:40 AM »
so i am use to measuring flat tops or dish,but sohc dome pistons are not the same.do you measure to the break where it transitions to dome?just need to know for sure,see pic.
Re: measuring compression height on sohc dome piston
« Reply #1 on: August 20, 2025, 07:20:16 AM »
That is correct - Jay
hbstang
« Reply #2 on: August 20, 2025, 11:28:56 AM »
thanks jay.with the stock ford aluminum heads and 4.350 bore and 4.375 stroke what would compression be with those pistons,as they are flat top dome of about .215 .i dont know chamber size on heads but thought you would if anybody knows.
i am going to email you a bunch of questions.
« Last Edit: August 20, 2025, 11:42:19 AM by hbstang »
« Reply #3 on: August 20, 2025, 12:18:34 PM »
Do you have a piston volume?
hbstang
« Reply #4 on: August 20, 2025, 12:27:49 PM »
no,i have no paperwork on pistons.
« Reply #5 on: August 20, 2025, 10:07:41 PM »
Those are fairly small dome by SOHC standards, a typical dome for an SOHC will be around 38cc.  Those look much smaller, but I really have no idea what they are...
hbstang
« Reply #6 on: August 26, 2025, 01:24:50 PM »
added a new calcution update
so i did some more checking and i think the dome volume on the pistons is 28 cc,or so.but with a chamber volume of 119 or so and bore 4.35,stroke 4.375 i get 10.87 compression .all of that maybe off some!
also bringing this up about combustion chambers,pond originally had a heart shape chamber on his but went back to the sohc open chamber. piston dome maybe only 20cc or so.low 10-1.want 11-1 or so.
also bore is 4.350 and piston skirts are 4.340,were for a blower combo,but how would they do for n/a 520 sohc?
https://fepower.net/simplemachinesforum/index.php?topic=514.0
« Last Edit: September 24, 2025, 03:52:39 PM by hbstang »
« Reply #7 on: August 26, 2025, 04:26:58 PM »
Gasket bore on your calculator should probably be 4.400", not 4.500".  Also if the piston is .015" in the hole you could go to a .041" head gasket, instead of the .051" that you are showing on the calculator sheet.  That would probably get you to 11:1 - Jay
hbstang
« Reply #8 on: August 27, 2025, 11:36:50 AM »
thanks jay,just trying to decide if i can use the pistons on a n/a build,but .010 piston to wall is not ideal.have you bought custom pistons from race tech for your sohc builds?
« Last Edit: August 27, 2025, 01:49:35 PM by hbstang »
« Reply #9 on: August 27, 2025, 04:13:27 PM »
Never used Racetec, I always get them from CP or Diamond.
« Reply #10 on: August 27, 2025, 04:30:13 PM »
Also, you should double check that C/R calculator before ordering pistons.  I very carefully measured out my original iron head street engine with TRW domed pistons (much bigger).  My chambers are 120 cc with slightly tuliped Donovan valves, and with an 0.040" head gasket I got 10.7:1 compression.
No way that little dome gives so much compression.  Those must be blower pistons.
« Reply #11 on: August 28, 2025, 06:01:59 AM »
I've been buying my cammer pistons from Mahle.  They have a nice lightening program, come coated, have a nice ring package.
hbstang
« Reply #12 on: August 28, 2025, 02:52:51 PM »
thanks every one for your replys.
« Last Edit: September 24, 2025, 03:34:19 PM by hbstang »
hbstang
« Reply #13 on: September 24, 2025, 03:41:16 PM »
after reviewing this a few time and rechecking the dome height, that this is a 520 inch short block,with 4.350 bore piston and 4.375 stroke.that combo does have an effect on swept volume over a standard 427.the little dome is .215 high and 4.1 average dia top to bottom,so that makes a cylinder volume of 41 ccs minus the valve notches,of approx 8 ccs.for a total dome volume of 33ccs.
1)also,did the sohc blocks have a highter deck height than a standard fe?
2)and are most sohc heads 120 ccs or so?
3)i have stock ford aluminum that i would use on this,or maybe some dove heads if i can get it repaired.
4) pistons are set up for pin buttons,can the be machined for normal wire locks or spiral locks?
« Last Edit: September 24, 2025, 03:58:51 PM by hbstang »
« Reply #14 on: September 24, 2025, 07:42:26 PM »
SOHC blocks had the standard FE deck height.  Stock chamber volume is right about 120cc.  Don't know about the pin buttons.
