Author Topic: measuring compression height on sohc dome piston  (Read 10811 times)
Re: measuring compression height on sohc dome piston
« Reply #15 on: September 24, 2025, 08:10:38 PM »
Plug your numbers in here:
https://www.summitracing.com/popup/calcsandtools/compression-calculator
Assuming zero deck height and 0.040" gasket thickness, you get around 12.0:1 with the numbers you provided above  :o :o
That's assuming the piston dome really does work out to 33 cc.
Color me surprised!  That big bore and stroke really do make a difference.  Note that you need to enter your piston dome cc as a negative number on the Summit calculator...
« Last Edit: September 24, 2025, 08:13:23 PM by WConley »
