Author Topic: 1967 Fairlane Super Stock  (Read 204392 times)
0 Members and 2 Guests are viewing this topic.
GPR
    • Gillis Restorations
Re: 1967 Fairlane Super Stock
« Reply #15 on: August 31, 2013, 09:56:13 AM »
Brian installed a Crites spring relocation kit.
Brian made a couple of gussets
Epoxy primed and seam sealed the wheelhouse
Rusty Gillis
Former NHRA SS/FA & SS/GA National Record Holder
bartlett
« Reply #16 on: August 31, 2013, 03:59:37 PM »
I would be adding some gussets to that spring perch ....
« Reply #17 on: September 01, 2013, 03:08:59 AM »
If you look closely, there is one thick looking gusset on the top of the offset part. Kind of deceiving in the picture....it looks like an extension of the frame.
Very nice work. The whole thread has been interesting.
GPR
« Reply #18 on: September 01, 2013, 03:14:14 PM »
The CalTracs would not fit so we had to trim the bracket.
We put it on the ground and found out the other side was in a bind. Months went by then finally we took it apart and modified the frame rail.
This was inside the frame rail
Brian made a patch
I started out this was going to be a race car than I changed my mind and it was going to be a street car so I sprayed the bottom with SPI bedliner. Changed my mind again after talking to Steve Baur the editor of Modified Mustangs and Fords Magazine since he wanted to do a series of Drag Racing related stories. I will leave it on there it can't weight that much. Now it is time to paint the car so we can start putting it together.
Ready for another round of primer
Sprayed a couple of coats of SPI white epoxy to make the red pop.
After a lot of wet sanding sprayed 3 coats of SPI Red the next day 3 coats of SPI Universal clear.
Rusty Gillis
falcon428
« Reply #19 on: September 01, 2013, 06:13:09 PM »
Looks great, gotta love the rotisserie.  It's definitely one of those tools I wonder why I didn't buy one sooner.  Money well spent.
Now I just need to find the time to work on mine, would like to get my 68 Falcon off the rotisserie soon.
Now if I would get off this here interweb and get into the shop I might get something done.  LOL
My Labor Day will be spent working on the 68.  Need to find some parts and get car ready for chassis shop.
Keep up the good work!
Rodney
'65 Mercury Comet w/ Pond Alum. 427, C6
'61 Ford Starliner w/ 352, C6
'68 Falcon w/ ProCharged FE, Lenco 5sp
'67 Country Sedan SW
'62 Falcon awaiting turbocoupe motor & tranny
'40 Ford Tudor Sedan all original
JamesonRacing
« Reply #20 on: September 02, 2013, 12:37:54 AM »
Really nice work, great to see all the pictures of the detail changes you made.
I did very similar mods to my 66 Fairlane GT, moving the springs inboard and Calvert springs, bars, shocks.  Calvert made custom perches for me so my shocks mount on the body in the stock location.
One regret I had when I did mine was that I should have narrowed the frame rail at the back of the wheel house where the inside of the tire will rub.  I'm using 10" wheels with 10.5x30 tires, but could run taller/wider tires if the frame wasn't so close.
GPR
« Reply #21 on: September 02, 2013, 12:33:41 PM »
I went with Opentracker roller front suspension http://www.opentrackerracingproducts.com/
I also installed their front strut rods
Wilwood brakes
« Last Edit: January 20, 2015, 01:53:27 PM by GPR »
Rusty Gillis
« Reply #22 on: September 02, 2013, 07:07:37 PM »
These are the struts I have on my '66 Fairlane; I also used Total Control's variable rate coil springs.
http://www.totalcontrolproducts.com/strut.html.
Bruce
66FAIRLANE
  • Andy
« Reply #23 on: September 03, 2013, 12:30:38 AM »
A question on the inboard spring relocation that I have always wondered about. The offset rear shackles move the spring over approximately 2". The front relocation perch moves the spring over considerably more, maybe 3-4". Does this mean the springs sit at an angle?
GPR
« Reply #24 on: September 03, 2013, 09:19:17 AM »
The frame rail is not that wide and the location is moved about 2 1/4" (hard to get an exact measurement on the ground) and the springs are straight.
Rusty Gillis
« Reply #25 on: September 03, 2013, 12:24:55 PM »
You shoulda painted it RED!! ;)
66FAIRLANE
  • Andy
« Reply #26 on: September 03, 2013, 05:37:59 PM »
Still not getting it. The spring is about 2" wide so putting it next to itself, ala rear hanger, moves it about 2". The frame rail at the front adds at least another 1-1/2". I must be missing something here.
GPR
« Reply #27 on: September 04, 2013, 08:11:49 AM »
The stock spring is on the outside of the frame rail in the front and under it in the rear that is the difference. The frame rail is not straight from the front spring hanger to the rear shackle.
Rusty Gillis
66FAIRLANE
  • Andy
« Reply #28 on: September 04, 2013, 08:22:33 PM »
Yeh I realise this. Not trying to be argumentative, just trying to understand. To me it doesn't matter where the frame rail is. You are still moving the spring about 2" at the back and about 3-4" at the front. If you move the spring the same amount at the front as you move it at the back it would sit directly under the frame rail. Obviously you can't do this so it goes on the inside of the rail. I am saying it is the width of this frame rail that is the difference. I am not saying what you are doing is wrong or anything, I love looking at your work and love this thread. I just can't see how the spring can remain straight and it probably doesn't matter.
« Last Edit: September 04, 2013, 08:27:24 PM by 66FAIRLANE »
GPR
« Reply #29 on: September 05, 2013, 08:58:01 AM »
You are NOT moving 3" or 4" in the front only the width of the frame rail or a little over 2".
Rusty Gillis
