Author Topic: 1967 Fairlane Super Stock  (Read 204441 times)
GPR
    • Gillis Restorations
Re: 1967 Fairlane Super Stock
« Reply #135 on: February 10, 2018, 06:16:22 PM »
Can you give us any specs on the engine, Rusty? I see it has BBM heads and a Victor intake.
I don't have the specs. I'm sure Russ67scode will answer that.
Rusty Gillis
Former NHRA SS/FA & SS/GA National Record Holder
GPR
« Reply #136 on: February 10, 2018, 06:22:14 PM »
Picked up this morning
Made it to its new home
Rusty Gillis
Russ67Scode
« Reply #137 on: February 11, 2018, 09:12:25 PM »
It’s new home right next to the mustang
Russ67Scode
« Reply #138 on: February 12, 2018, 09:02:12 PM »
Doug it’s the engine out of my 67 mustang. To make a long story short I put a new Detroit locker and new gears in the rear. I hammered the throttle and the car hooked a HARD left  I hit the brakes turned the wheel and the mustang slid down the grass bank spun around came across the road and when it hit the grass on the other side it dug in and rolled over
« Last Edit: February 12, 2018, 09:11:17 PM by Russ67Scode »
Russ67Scode
« Reply #139 on: February 12, 2018, 09:23:39 PM »
Sad pictures
« Reply #140 on: February 13, 2018, 09:23:12 AM »
Oh man, that's terrible. Were you seeing if the turbos worked?
« Reply #141 on: February 13, 2018, 09:30:02 AM »
Wow, that is sad. So sorry. :-[ :'(
Have to ask though. Was the road crowned or flat? Rear steer for sure or did the car wheelie enough to lose steering control?
« Reply #142 on: February 13, 2018, 10:44:20 AM »
 :o OUCH :o sorry to see that
Russ67Scode
« Reply #143 on: February 13, 2018, 10:57:23 AM »
Running just on the engine it makes close to 700 lbs of tq that way
The road does have a crown,Bob Maag look st last picture.  problem with the locker and about 7 lbs difference in tire pressure
Still sick to my stomach as I have had this mustang 28+ years
« Last Edit: February 13, 2018, 11:00:38 AM by Russ67Scode »
Russ67Scode
« Reply #144 on: February 13, 2018, 11:03:15 AM »
Went to edit some spelling errors and half my typing went away.
 Well the fairlane will be faster and the extra wheel base will help
« Reply #145 on: February 13, 2018, 12:02:53 PM »
Well not anything a port o power and some
hammer and dolly time can’t fix
I have saved Mustangs worse than that
No Rust in the lower windshield corner
a good indicator for a rustfree Mustang
« Reply #146 on: February 13, 2018, 12:04:43 PM »
I'm sick for you Russ
« Reply #147 on: February 13, 2018, 06:37:29 PM »
Wow, I feel terrible for you, Russ. That just plain sucks! First, I'm glad you weren't hurt! You must have had your seatbelts on. I've had my car for 34 years, so I know what you must be feeling, as far as losing an old friend.
I'm glad you got a new project to put the engine in, but I also hope you don't give up on the Mustang. Or at the very least, see that it goes to someone willing to put the time and effort into getting her up and rolling again. Not an easy task, but it's doable.
mike7570
« Reply #148 on: February 13, 2018, 08:37:06 PM »
Tub it!
Time for full cage fiberglass doors, fenders and hood and new metal roof (think George Vega)
You can have it looking good and much lighter too. My '69 only had a metal roof and rear quarters.
« Last Edit: February 13, 2018, 08:46:27 PM by mike7570 »
Russ67Scode
« Reply #149 on: February 18, 2018, 08:35:50 AM »
Yesterday I installed the narrowed rear, pressed the bearings in the 35 spline axles and screwed in the wheel studs. Test fitted a set of wheels I had , ended up having to run them backwards to fit
Trying to attach photos
