Author Topic: Giggling like a school girl  (Read 150441 times)
Re: Giggling like a school girl
« Reply #15 on: June 30, 2013, 01:39:02 PM »
I did. But with the VIN matching an "H" code 390 and what looks to be a C6 trany I was not sure what to make of it.  :o
I'm thinking the PO liked to mess wif yo mind.
« Reply #16 on: June 30, 2013, 05:32:01 PM »
Looks like a solid car.
Couple of big ticket items with it also.
Buy the factory service manual. Best 20 or so bucks you can spend right now.
The next 10 grand is just for fun. ::)
66FAIRLANE
  • Andy
« Reply #17 on: July 01, 2013, 07:53:17 AM »
Good score! Might have a soft spot for them myself :)
Just for your interest here is what an Aussie 67 Fairlane dash looks like.
« Last Edit: July 01, 2013, 08:01:36 AM by 66FAIRLANE »
« Reply #18 on: July 01, 2013, 11:10:14 AM »
Roger the manual and if it's only ten grand I'll be smiling a lot.
Not that it's not a lotta dough.
« Reply #19 on: July 01, 2013, 04:12:06 PM »
That's nice, and looks sharp but I'm really pervin' on the R code panels clean lines.
BTW
Found out a little more info.
The 9 inch has 3.55s and a limited slip.
Don't know what the C6/rear gear/desired rpms will work out to yet but I do know I'll prolly throw a locker in it.
« Reply #20 on: July 04, 2013, 12:25:21 AM »
Hmmm
This block is interesting.
I can't find the foundry mark (pic below) in any reference material.
Pulled the freeze plugs out (brass) and a 17/64 bit will not fit between the cylinders.
15/64 will.
Bores are .4.07.
« Last Edit: July 08, 2013, 06:36:24 PM by turbohunter »
GJCAT427
« Reply #21 on: July 04, 2013, 06:00:46 AM »
Turbohunter, if you clean the block with a wire brush, I believe you will find its a DIF. the F is not real defined. I have run across marks that are not fully formed when the cores are formed before casting. Date codes are usally very prone to this.
« Reply #22 on: July 04, 2013, 08:21:27 AM »
Did it.
Yeah you're right it looks like there's a ghost of the rest of the F there.
Ok off to a clean up mag and sonic check.
Since I  have the crank it would be fun to make a 428 for the Fairlane but if this block doesn't measure up I'll either find something else or go down the stroker road.
« Last Edit: July 08, 2013, 06:38:34 PM by turbohunter »
« Reply #23 on: July 04, 2013, 12:28:10 PM »
  Can't see much of them in your photo, but are they the race Hooker headers?
Hooker Super Comps
I updated the pic a few posts back.
Finally got a chance to dig into the pile in the car.
Found the rear floor pans are toast. Thats an easy fix.
Also an almost new ED aluminum water pump.
garyv
If you would like to sell the radio delete dash let me know.
« Reply #24 on: July 06, 2013, 07:28:01 AM »
I have been looking for one for my 66.
you ended up with a lot of nice stuff.
now the fun begins.
enjoy
garyv
« Reply #25 on: July 08, 2013, 06:33:45 PM »
Thanks Gary but I'm into those clean lines of that dash.
Upon closer inspection it has a small crack in the middle of it right above the g in "lighter".
Finally have some time to crawl around and under it.
Question for you guys.
Is this the norm for Fairlane 9 inchers?
This housing has a fill plug in the rear next to the hump as well as a fill hole on the carrier side as a standard 9 usually does.
I only thought the dimpled housings had the rear fill.
Also has tapered tubes (though its a slight taper) like Hipo mustangs did..
The more I look at that housing the stranger it looks.
« Last Edit: July 08, 2013, 06:42:12 PM by turbohunter »
fe66comet
« Reply #26 on: July 09, 2013, 06:51:48 PM »
You made out way better than me on my 66 comet. Later on is when I found out you can't get a single part for it new or used. Really a waist of money. I can't even find good headlight rings or a core support, no trim, no door panels, not even a package shelf or carpet in the maroon color.....Jon
amdscooter
« Reply #27 on: July 09, 2013, 10:56:22 PM »
Vent hose is discombooberated in this pic..... but yours looks the same as the 9" in mine.
« Reply #28 on: July 10, 2013, 10:24:39 AM »
I'm beginning to figure that out.
It's not like getting on the web and ordering a part, like a mustang or a truck is it.
I figure we should embrace (what else can you do) that it's tough to find parts because they're not run o' the mill cars.
Tell you one thing though. I'm going back to scavenge the POs place like a starving buzzard.
« Reply #29 on: July 10, 2013, 10:33:28 AM »
Well that's cool/interesting.
At least I know now it's not a hack job, but I had no idea this configuration existed.
Have tried to find them searching web but have not yet.
I was thinking of replacing it but since it is a factory piece I think I'll keep it and just upgrade it.
Thanks for posting that.
