Author Topic: Adjustable timing pointers are here and ready to ship!  (Read 20842 times)
« on: August 31, 2021, 05:52:39 AM »
Would there be a lot of interest in these?  It seems like every build I do, I'm having to grind, slot, file, etc., to get the pointer aimed at the correct spot on the balancer.
I'm looking at having some billet aluminum pointers made, that would allow for up to 8° of adjustment.   These would sell for about $25 each and would work with either style timing cover.
Interest?
« Last Edit: October 08, 2021, 06:39:07 PM by blykins »
chilly460
Re: Gauging interest in new product: adjustable timing pointer
« Reply #1 on: August 31, 2021, 06:18:05 AM »
+1
63galnc
« Reply #2 on: August 31, 2021, 06:24:54 AM »
+1
hwoods
« Reply #3 on: August 31, 2021, 06:27:24 AM »
+1
MeanGene
« Reply #4 on: August 31, 2021, 06:31:12 AM »
Yep
« Reply #5 on: August 31, 2021, 08:16:09 AM »
I’ll take two
« Reply #6 on: August 31, 2021, 08:18:02 AM »
I've got one 3D printed, so I'll try it out later today.  If I'm satisfied with it, I'll order 'em up.
BigBlueIron
« Reply #7 on: August 31, 2021, 01:49:32 PM »
I'm in for one if it allows for enough swing for the ATI balancer
« Reply #8 on: August 31, 2021, 04:06:22 PM »
Think ATIs are 7 degrees off. Brent is thinking 8 degrees of adjustment.
Wonder if mounting hole misalignment might make that a bit tight Brent?
« Last Edit: August 31, 2021, 04:09:25 PM by turbohunter »
« Reply #9 on: August 31, 2021, 04:46:18 PM »
The ATI's are 7 degrees off.  I'm not sure if I can swing it that far in one direction without making a fairly large 2-piece pointer, where the pointer is separate and swings along an arc.  That wasn't my intention.
There will be a couple of "generalities" with this.  I will make it sit so that it will clear most aftermarket balancers (Romacs are 6.200", Powerbonds are 6.980", ATI's are 7.070"), but there will also be differences in where the timing marks are located, down the middle of the balancer, along the outside edge, etc.   I will try to aim to hit around the middle of the width of the balancer with the end of the pointer.
What I usually do on the ATI's, when I use them, is to use timing tape.
My goal is just to make a simple billet pointer, with some significant slots for the holes so that it can be moved enough to allow for common discrepancies, maybe 4° in each direction.
« Last Edit: August 31, 2021, 05:08:13 PM by blykins »
Joey120373
« Reply #10 on: August 31, 2021, 09:46:22 PM »
ill buy one
475fetoploader
« Reply #11 on: September 01, 2021, 06:52:41 AM »
I would like one
1967  519 c.i.  TKX 5 speed
« Reply #12 on: September 02, 2021, 12:02:13 PM »
Ok, I have these finalized and the order placed.  I should have them by the first week of October, I ordered quite a few.
I'll post when they come in.
On the engine I have sitting on the stand, the pointer allows me to adjust in a span of 10°.
Final price with stainless screws and washers will be about $28 plus shipping.  I'm gonna snag a load of USPS Priority small flat rate boxes, so you can count on about $6 for shipping.
gdaddy01
« Reply #13 on: September 02, 2021, 08:58:48 PM »
one
gregb
« Reply #14 on: September 08, 2021, 10:52:44 AM »
I'm in for one....
