FE Technical Forum
FE Engine Dyno Results
Lincoln Y Block dyno result
Topic: Lincoln Y Block dyno result (Read 6766 times)
Royce
April 13, 2021, 02:52:02 PM »
Dan sent me a dyno sheet yesterday for an engine that I helped him make parts selections. It is a stroked 368 at 392 inches. ported stock 57 heads, 10:1 compression 224 degree hydraulic roller. Custom intake spacers from FEPOWER LLC. A scrub Performer RPM intake and an AED Holley 750. It's going in a 53 Lincoln Cosmo with a 6 speed automatic and 4:11 gears.. Should be fun.. Damn it makes torque.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
Kaase Boss 547. 840 HP 698 Torque pump gas
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Lincoln Y Block dyno result
Reply #1 on:
April 13, 2021, 02:56:04 PM »
Nice work!
DEANs427
Full Member
Reply #2 on:
April 13, 2021, 03:55:15 PM »
All that torque at comparatively low rpm, might not need that deep of gear.
My little Y block max torque rpm is at higher rpm.
Great job !
Last Edit: April 13, 2021, 04:01:31 PM by DEANs427
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
Reply #3 on:
April 13, 2021, 04:41:29 PM »
Sweet.
Administrator
Reply #4 on:
April 13, 2021, 07:45:16 PM »
It was those trick intake spacers
Reply #5 on:
April 14, 2021, 01:12:39 PM »
I've always admired the 368!
In about 1964, in the LB/Signal Hill area of CA, there was a very fast one, in a '56 Ford.
We know the adapter helped a lot but, do you have info on the heads and flow or did those long rods, make all that torque?
Reply #6 on:
April 15, 2021, 09:20:46 AM »
It's gonna need that torque in that car!
That's a pretty impressive torque curve for a Y-block. With that automatic, it should be able to keep up with modern traffic just fine, with a little concession to fuel mileage..lol
Royce
Reply #7 on:
April 15, 2021, 10:09:20 AM »
I think the torque was made by really good heads A long intake runner and a spot on cam ..
A max ported Lincoln head will do about 260 on the intake and 200 on the exhaust. Joe's ported Lincoln heads can do just a bit better than that. My 383 inch Lincoln made 500 torque with 12:1 a tunnel ram and a big solid roller, so this pump gas motor is quite impressive.
Oh and we must not minimize the Jay Brown factor since he produced the intake adapters.. His stamp is worth 20 ft lb
Last Edit: April 15, 2021, 10:12:43 AM by Royce
1992 BMW V-12 5.0
FE Technical Forum
