Author Topic: Lykins Motorsports 496FE, Ported TFS Heads  (Read 10194 times)
« on: April 03, 2021, 05:28:14 AM »
Performance Summary:
      Cubic Inches:  496             Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  643 @ 6200
      Peak Torque:  650 @ 4200
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  BBM Cast Iron, 4.310" Bore, 10.150" Deck
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4340, 4.250", 2.200"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  K1 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond, forged, 26cc, 10.6
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite 351C main bearings, Calico coated Clevite rod bearings, Durabond FP-01 cam bearings
   Piston rings brand, size, other notes:  Total Seal .043/.043/3mm, standard tension
   Oil Pump, pickup, and drive:  Melling M57HV, Aviaid pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Aviaid Cobra pan, factory CJ repop adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller, 245/252 @ .050", 114 LSA, .630"/.620" lift at valve
   Lifters brand, type:  Morel hydraulic roller, standard travel
   Timing chain and timing cover: Cloyes billet, factory cover
   Cylinder heads brand, material, port and chamber information: Trick Flow, ported, 360 cfm
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  TFS, 2.190"
   Exhaust valve brand, head size, stem size:  TFS, 1.625"
   Valve springs brand, part number, specs:  Comp Cams 26120 Beehive
   Retainers and locks brand, part number, specs:  Comp Cams, steel
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports, non-adjustable roller tip, 1.76
   Rocker shafts and stands, brand, material:  Harland Sharp
   Pushrods brand, type, length:  Trend, 5/16", various length
   Valve covers, brand, type:   Cobra Lemans, polished
   Distributor brand, advance curve information:  MSD, steel gear, black cap
   Harmonic balancer brand:   Romac
   Water pump brand, type (mechanical or electric):   Edelbrock
   Intake manifold brand, material, porting information:  Fully ported Performer RPM
   Carburetor(s) brand, type:  QFT Q-850
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
« Last Edit: April 24, 2021, 05:14:51 AM by blykins »
Re: Lykins Motorsports 496FE, Ported TFS Heads
« Reply #1 on: April 03, 2021, 05:28:59 AM »
gdaddy01
« Reply #2 on: April 23, 2021, 08:20:46 PM »
not that I can afford it , but what price range would this combo be in ? how many different  length push rod did you have ?
« Reply #3 on: April 23, 2021, 09:07:54 PM »
Brent is that a solid roller with hydraulic roller lifters?. I think a while back you were talking about this setup. If its not a typo what are the advantages, and can you use your rockers on this with the right size pushrods. Nice though.
475fetoploader
« Reply #4 on: April 24, 2021, 02:24:57 AM »
Nice solid combo!
1967  519 c.i.  TKX 5 speed
« Reply #5 on: April 24, 2021, 05:13:30 AM »
With the ported heads, aftermarket block, Aviaid pan, etc., this was a ~$22-23k engine build.
Two lengths of pushrods.
« Reply #6 on: April 24, 2021, 05:14:30 AM »
It is a typo, thanks for catching it, I'll get it fixed.   When I copied and pasted another build, I forgot to change it.
It's a hydraulic roller cam with hydraulic roller lifters.
« Last Edit: April 24, 2021, 06:07:48 AM by blykins »
Sand hauler
« Reply #7 on: April 24, 2021, 09:34:52 PM »
Very nice build should run a long time with out any issues.
Bobby-   Carlsbad, NM
gdaddy01
« Reply #8 on: May 01, 2021, 10:03:04 PM »
thanks , Brent , nice build and nice to deal with someone that is a straight shooter .
pkm123
« Reply #9 on: September 29, 2021, 11:09:45 AM »
Love the build.  I am freshening up my 452FE.  I have a 8 stack ITB fuel injection setup that I made myself.  I have a soft spot in the torque curve between 1100 rpm and 1600 rpm, so I am switching the cam from a Street Roller 248/256 on a 110 LCA to a SR 240/246 on a 114.  Both cams were +4.  Please tell me why do you have the 496 cam installed +8?
