Author Topic: Fairlane subframe  (Read 5005 times)
Fairlane subframe
« on: March 04, 2021, 06:08:53 AM »
Anyone with a Fairlane 66-67 that can meassure the front framerails
Outside to outside. We have bought a Jaguar XJ12 frontend for stepsons
Fairlane but the car is snowed in for couple of months more so....
Re: Fairlane subframe
« Reply #1 on: March 04, 2021, 08:49:53 AM »
No problem Heo, I'll go out and measure mine and post it a little later today if no one has chimed in before.
« Reply #2 on: March 04, 2021, 09:23:21 AM »
BIG thanks
« Reply #3 on: March 04, 2021, 09:24:07 AM »
Will try to measure my 67 Falcon tonight, for comparison - should be the same measure.
« Reply #4 on: March 04, 2021, 09:28:29 AM »
THANKS X 2
Internet is full of Mustang frame diagram bit no Fairlane
« Reply #5 on: March 04, 2021, 01:23:22 PM »
Heo, my rails measure outside just under 29".  I measured them at the point where the rails come down from the engine compartment and curve parallel with the ground.  They then appear to taper inwards until they terminate after the trans crossmember. Hope that helps!
A Jaglane - should be an interesting project!   :D
« Reply #6 on: March 04, 2021, 03:04:54 PM »
Well then there is plenty of space. 34inch if i have the right information,  I Will have it delivered tomorrow
So i can start meassuring.
I think it can be great, vented discs,4 pistoncalipers, rpstearing ,about same tracwidth, getting rid
of shocktowers ,wheight 260lbs with pallet paid about 100USD. It unbolts from the jag as a complete unit
Dont know yet if we weld it in or bolt it on
« Reply #7 on: March 04, 2021, 03:27:35 PM »
Bruce can i ask for one more favor? From the ground up to bottom of framerails
About Where center of frontaxle is
O
« Reply #8 on: March 05, 2021, 08:58:07 AM »
Ok, will report back later today.  Luckily my car sits at more or less stock ride height.
« Reply #9 on: March 05, 2021, 09:16:26 AM »
That would be Nice, so i know if i have to modify the crossmember or the framerails
Katz427
« Reply #10 on: March 05, 2021, 10:57:35 AM »
I do have the chassis repair diagram for the 1967 Fairlane wagon. Front is the same. If you need it.
« Reply #11 on: March 05, 2021, 01:01:26 PM »
Heo, ok the distance from the ground to the bottom of the frame rail at the center of the front tire is about 14".  My car is about at stock ride height but the front tires are probably a little taller than stock.
I may have misled you about the width of the front frame rail: yesterday I measured the width of the rails behind the torque boxes.  From the front of the torque box forward, the rail is a box section which has an outside width of 33 3/4".  The box section itself is about 2 3/8" wide, so that gives an inside dimension of 29".  Bruce
« Reply #12 on: March 05, 2021, 02:00:53 PM »
Thanks katz but when i started to use my head i remembered
a friend have a 66 in a rotisseries  ::) He also had the shopmanual
With those repair diagrams
Thanks Bruce
I have the frontend at home now
The Width between the towers for the upper  A-arms is 34+ inch
So the framerails fit down between them, with 14 inch from Rail
to ground i think the height will  be about right without modyfie
framerails
