Author Topic: Powernation Junkyard FE gets Fuel Injection  (Read 3431 times)
hwoods
Yellow Truck
Re: Powernation Junkyard FE gets Fuel Injection
« Reply #1 on: February 11, 2021, 02:11:01 PM »
For all that trouble and expense they only gained about 5 horsepower and foot-pounds. I assume that the limit for power was elsewhere, possibly the cam.
Paul.
1968galaxie
« Reply #2 on: February 12, 2021, 10:39:31 AM »
Wow!
Spend over $3,000.00 (dual carb tunnel port manifold, dual fitech, fuel system upgrades) all for 5 HP?
I would have loved to see 2 carbs on the tunnel wedge.
However, this was an advertisement for fitech.
No back-to-back testing against a carb would ever be permitted.
These television shows are not free - advertisers pay.
Blueoval77
« Reply #3 on: February 12, 2021, 10:43:46 AM »
If it was tuned you can be sure it would meet or exceed the carbs numbers  However if you get the best guy tuning the EFI and the best guy tuning the carb they should turn out to be just about the same in the end... So maybe.........
In that environment all you are asking it to do is make power . Its off the Dyno and in the car that the big difference occurs.
