Author Topic: Billet heads  (Read 9124 times)
bobb428
Billet heads
« on: January 19, 2021, 06:03:45 PM »
What ever happened with the billet canted valve heads? Jay, did you ever think about casting off that design? Now a cheaper version is what I want!
SDC10598 by Bob Smith, on Flickr
Re: Billet heads
« Reply #1 on: January 19, 2021, 07:32:09 PM »
Too far from a normal FE for me.  FE valve covers won't fit, intake doesn't have the valve cover rail in it, etc.  Besides, canted valve heads mean a bigger chamber (which isn't good), and you can get the same effect as canting the valves by just raising the port (which is what I did on my heads).
Re: Billet heads
« Reply #2 on: January 19, 2021, 08:04:06 PM »
A few more pics I found:
Re: Billet heads
« Reply #3 on: January 19, 2021, 08:58:24 PM »
Did this setup run
bobb428
Re: Billet heads
« Reply #4 on: January 19, 2021, 10:09:33 PM »
The carb'ed combo went a 8.32@159 before the owner wrecked the car.
bobb428
Re: Billet heads
« Reply #5 on: January 19, 2021, 10:13:47 PM »
Boy I want that carb combo!!!!!
Re: Billet heads
« Reply #6 on: January 19, 2021, 10:45:10 PM »
https://www.visnerengine.com/billet-cylinder-heads/ford/fe-ford.html
Visner still offers these, but like Jay said, I don't think the FE crowd goes for them because they don't resemble an FE. For the money 385 series would be much cheaper and would look about the same.
bobb428
Re: Billet heads
« Reply #7 on: January 19, 2021, 11:11:43 PM »
It's not because they don't go for them, It's because there expensive! All the FE racers I know would drop on them if they weren't so expensive along with the supporting hardware! Better than any FE head out there!
bobb428
Re: Billet heads
« Reply #8 on: January 19, 2021, 11:15:32 PM »
If you are worried about looks, you have bigger problems!
Re: Billet heads
« Reply #9 on: January 20, 2021, 12:25:59 AM »
Re: Billet heads
« Reply #10 on: January 20, 2021, 08:23:29 AM »
I'll guess a cool $20K just in the complete heads, intake (less carbs, EFI) rockers and pushrods.
Maybe $30k for a complete engine, carbs too pan, flywheel to dampner, ready-to-run?
Anyone have pricing?
Royce
Re: Billet heads
« Reply #11 on: January 20, 2021, 09:20:44 AM »
385/BBC head on an FE block..Of course it's going to make a lot of power..
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Billet heads
« Reply #12 on: January 20, 2021, 10:44:04 AM »
When I look at that, I don't see a FE.  I see a custom one of a kind engine that just goes to prove that money will buy speed for those that have it to spend.  I prefer the look of factory, and make it as good as can be within the architecture of factory appearance.  Anything else is custom, and should race in a class of its own.  Billet vs cast is like knife vs gun.   Joe-JDC
fryedaddy
Re: Billet heads
« Reply #13 on: January 20, 2021, 04:02:04 PM »
really everything that dont bolt up to or replace factory or factory looking is custom.even the adapters are custom in my opinion.they do change the look of a fe to some point.
Plumber
Re: Billet heads
« Reply #14 on: January 24, 2021, 04:09:38 AM »
Looks like Ultra Pro Machining in NC makes them too.
