Author Topic: CVR Electric Water Pump Adapters  (Read 22782 times)
« on: February 28, 2013, 08:46:53 PM »
Now for sale are machined billet aluminum adapters to allow the CVR Proflo Extreme electric water pump to bolt onto FE engines.  For more information, or to purchase a set of these adapters, please visit the link below:
http://www.fepower.net/Products/cvradapt.html
The long, drawn out ( ;)) process for getting them designed and machined is covered in this thread on the technical forum:
http://fepower.net/simplemachinesforum/index.php?topic=706.0
Pricing is as follows:
Part #12001 - Plain set, no mounting points for factory brackets:  $145.00 per set plus shipping
Part #12002 - Set with mounting points for factory alternator brackets:  $185.00 per set plus shipping
Part #12003 - Set with mounting points for factory alternator brackets and factory power steering pump brackets:  $225.00 per set plus shipping
Part #12004 - Set with mounting points for factory alternator brackets, to fit the SOHC engine:  $185.00 per set plus shipping
Thanks for all the support on this project - Jay
« Last Edit: January 31, 2017, 09:41:36 AM by jayb »
afret
Re: CVR Electric Water Pump Adapters
« Reply #1 on: February 28, 2013, 09:06:53 PM »
Order sent.  Thanks!   :)
« Reply #2 on: February 28, 2013, 09:36:53 PM »
Thank-you, Earl.  You are using them on an aftermarket block, correct?  Is it OK if I send you one with the round O-ring on the right side?  I checked the fit on my Shelby and Pond blocks, and the O-ring fits around the water jacket opening with no problem.
afret
« Reply #3 on: February 28, 2013, 10:20:50 PM »
I'm using them on a Genesis with round holes so that would be fine.  I should have mentioned that on my order.  Sorry about that.
« Reply #4 on: February 28, 2013, 10:29:42 PM »
No problem, and thanks.  I'll get them out in the morning.
fetorino
  • Tunnelport Cobra
« Reply #5 on: March 01, 2013, 06:21:41 PM »
Jay
Thanks again for the effort on these.  I see my set got delivered.  Just what every well dressed TP needs. ;D
Rob
fe66comet
« Reply #6 on: July 06, 2014, 09:51:03 PM »
Hey Jay I den a message the other day was just wondering if you got it? Thanks Jon
« Reply #7 on: July 06, 2014, 10:10:33 PM »
Just got it and sent you a PM, Jon  - Jay
« Reply #8 on: December 20, 2015, 11:17:42 PM »
Do these allow the pump to clear belt drives or will spacer's be needed and are they also available ?
« Reply #9 on: December 21, 2015, 12:58:30 AM »
You mean timing belt drives like the Danny Bee, right?  I haven't specifically checked that, but the Danny Bee belt drive fits behind the factory water pump, and the CVR pump plus the adapters has the same clearance in the back as the factory water pump, so I'm pretty sure there would be no problem - Jay
« Reply #10 on: December 21, 2015, 12:41:20 PM »
Thanks jay, I have acquired a nice used DannyBee that just needs a belt and a tensioner and some hardware. Everything I need is available from DannyBee. I'm thinking of using it or replacing the needed parts and re selling it. I'll have plenty of room out front and was thinking that if I did use spacer's it would allow more room for making adjustments. It's good to know that the pump would fit without them though. You still have some of the basic adapters in stock m guessing ?
« Reply #11 on: December 21, 2015, 02:01:59 PM »
I just finished up another production batch and have them all in stock - Jay
« Reply #12 on: February 19, 2016, 10:42:51 PM »
Do you have the cvr pumps as well or just the adaptors ? I'll be making an order in a couple weeks. Just trying to save a few bucks, if you don't have the pumps would you recommend me going straight through CVR website or through sumitt/jegs ?
« Reply #13 on: February 20, 2016, 12:14:51 AM »
I don't have the pumps and inlet tubes here, Keith.  I'd go through Summit or Jegs to get them, I think that's cheaper than going direct to CVR - Jay
« Reply #14 on: February 20, 2016, 12:35:14 AM »
Just as an FYI, of the two big mail order stores I've only seen the CVR products at Summit. I don't think Jegs carries them.
