Author Topic: RAM Race Clutch 1 3/8  (Read 6029 times)
427rouser
« on: December 01, 2020, 11:18:55 PM »
Ram race clutch 1 3/8 11" adjustable plate, all new with throwout bearing. 792.00 currently through Summit 500.00 plus shipping from 40391.
475fetoploader
Re: RAM Race Clutch 1 3/8
« Reply #1 on: December 01, 2020, 11:57:12 PM »
Does Ram give any “up to horsepower” rating for that setup? I didn’t see anything on there website, maybe you recall something?
1967  519 c.i.  TKX 5 speed
« Reply #2 on: December 02, 2020, 04:52:55 AM »
650-700ish, depending on variables.
475fetoploader
« Reply #3 on: December 02, 2020, 10:37:05 AM »
So if I had a light-ish car, 800 h.p. 4.56rear   Maybe, I could make this work, and not break a Toploader.  Using street tires of course.
« Reply #4 on: December 02, 2020, 02:34:33 PM »
If you have street tires and no traction, you can probably get away with it for a while, but even 3rd gear romps would eventually cause issues if you run that much power through it; the main shaft and counter shaft will deflect. Other than the added beef on the output spline area and input shaft, the main shaft between small and big inputs are the same size, so there is no added strength to a big input when putting the power to it after a launch. Add slicks and any type of traction, and the toploader will be short lived at that power level, regardless of input shaft size.
475fetoploader
« Reply #5 on: December 02, 2020, 06:55:19 PM »
I can just have Blair leave a bunch of material in the intake ports, to cut down on parts breakage.  Bahahaha!
475fetoploader
« Reply #6 on: December 02, 2020, 06:57:50 PM »
Pm sent about clutch
427rouser
« Reply #7 on: December 02, 2020, 08:07:35 PM »
Messaged back.
427rouser
« Reply #8 on: December 06, 2020, 06:38:58 PM »
Messaged back.
[/quote/
Messaged shipping cost and phone number.
475fetoploader
« Reply #9 on: December 20, 2020, 07:02:48 PM »
Received clutch, looks great, well packaged.  Thank you, I will put it to good use.
427rouser
« Reply #10 on: December 23, 2020, 09:40:36 AM »
Fantastic thanks again.
