Author Topic: Felpro intake gaskets  (Read 4385 times)
GJCAT427
« on: December 01, 2020, 05:51:19 PM »
I was checking on felpros site and there info says that the 1247 & the 1246 gaskets are print o seals. I seem to remember that they were teflon coated but no silicon bead. Am I wrong? I have some that are definitly non silicon beaded and was going to get some more but don`t want the bead. When did they change? Also has anyone got an opinion on Mr Gasket 206g & 202a ? thanks GJCAT
Re: Felpro intake gaskets
« Reply #1 on: December 01, 2020, 05:55:14 PM »
The Mr. Gasket gaskets are about all I use.
Keith Stevens
« Reply #2 on: December 01, 2020, 07:18:03 PM »
Don't use the 1246 or 1247.  You'll want to use the 1246-S3 for tall ports, the 1247-S3 for small ports. The S3 version is a steel laminate and doesn't sog and get sucked into the port like the original Printo seal gaskets.
« Reply #3 on: December 01, 2020, 10:19:19 PM »
I used mostly Mr. Gasket 202A gaskets during all my intake testing.  They always seem to work well.
wayne
« Reply #4 on: December 05, 2020, 08:46:35 AM »
All i use is mr gasket they work good for me.
« Reply #5 on: December 05, 2020, 08:49:56 AM »
I like the Mr Gasket as well, but if the blue Felpro kit gaskets fit (they are pretty thick) and seal to your intake, pretty easy to use and hard to beat for price and sealing
rockhouse66
« Reply #6 on: December 05, 2020, 03:54:30 PM »
You have solid replies from real engine builders here, but I have assembled 3 or 4 FE engines with the Mahle MS15166X intake gaskets and have had great results.
Jim
GJCAT427
« Reply #7 on: December 05, 2020, 07:54:23 PM »
I`ve used Felpros for yrs, I was just looking to replenish my stock and discovered that they had changed to using the blue seal bead on the the better gaskets. I`m about to order some gaskets and I think it will be the Mr Gaskets this round. Thanks guys
