Author Topic: Lykins Motorsports Project Junky Junk 352 Iteration #4, 433 HP @ 6800  (Read 7383 times)
Performance Summary:
      Cubic Inches:  359             Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  433 @ 6800
      Peak Torque:  405 @ 4500
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory C6ME-A, 4.040"
   Crankshaft brand, cast or forged, stroke, journal size:  FoMoCo cast 352 crankshaft, .020"/.020"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar Ford FE 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec 4032, 1.920" compression height, flat top, 10.4:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated King main bearings, Calico coated King rod bearings, Durabond FP-33 cam bearings
   Piston rings brand, size, other notes:  Mahle 4.040", 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57B, custom pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Custom stock appearing oil pan with oil control gates and baffles, no tray, new filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid roller, 256/266 @ .050", 106 LSA, .650"/.670" lift at valve
   Lifters brand, type:  Comp Cams Endure-X
   Timing chain and timing cover: FE Power adjustable timing set and FE Power 2-piece timing cover
   Cylinder heads brand, material, port and chamber information:  C6AE-R
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  Custom 2.090", 5/16" stem stainless
   Exhaust valve brand, head size, stem size:  Custom 1.650", 5/16" stem stainless
   Valve springs brand, part number, specs:  PAC small diameter dual spring
   Retainers and locks brand, part number, specs:  Manley titanium retainers, Manley locks, Victory lash caps
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports, non-adjustable roller tip
   Rocker shafts and stands, brand, material:   Precision Oil Pumps billet aluminum
   Pushrods brand, type, length:  Smith Brothers, 3/8" .145", various lengths
   Valve covers, brand, type:   Scott Drake PBF
   Distributor brand, advance curve information:  Factory Ford, locked out, Pertronix conversion
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   New cast iron replacement
   Intake manifold brand, material, porting information:  JDC ported PI "F"
   Carburetor(s) brand, type:  Holley 830
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
« Last Edit: November 24, 2020, 11:40:28 AM by blykins »
Re: Lykins Motorsports Project Junky Junk 352 Iteration #4
« Reply #1 on: November 17, 2020, 08:39:03 AM »
475fetoploader
« Reply #2 on: November 17, 2020, 05:16:45 PM »
Greetings Brent, I sent a pm about a clutch, wondering if you had a chance to look at it. Thanks!
1967  519 c.i.  TKX 5 speed
