Non-FE Discussion Forum
Timken, Spicer differential 1952 ford 3/4 ton
Topic: Timken, Spicer differential 1952 ford 3/4 ton (Read 3924 times)
Katz427
Sr. Member
November 05, 2020, 07:45:32 AM »
Any one with any experience on these? The pinion seal is a leaker,( just sitting there) the newer seals, just seem to leak. No problems with the old leather seals.
Re: Timken, Spicer differential 1952 ford 3/4 ton
Reply #1 on:
November 05, 2020, 08:34:40 AM »
No bearing or yoke issues? Clearly coming from the seal at the yoke?
I haven't worked on one of those rears, but if everything is stable, shouldn't be too hard to seal up, at least more than leaking just sitting there LOL.
frnkeore
Reply #2 on:
November 05, 2020, 12:45:39 PM »
Your going to have to pull the yoke and if it has a groove in it, you'll have to have it turned down and a sleeve installed.
Frank
'60 Ford Starliner
'61 Fairlane 500
Katz427
Sr. Member
Reply #3 on:
November 05, 2020, 02:53:23 PM »
Thanks for replying. Strange contraption, has an electric motor connected by belt drive and pulleys to a shaft going to a 3 foot shaft driving the Timken which drives platform and spinning cars for a carnival ride. So the differential is on it's side with the side bells vertical. The rebuilder put a new seal in but it leaks just sitting, no load applied.
gdaddy01
Reply #4 on:
November 05, 2020, 07:32:55 PM »
on a lincoln nine inch rear , I had to put sealer on the outside of the seal , where it goes into the housing , to get it to seal , maybe look into doing that . kinda like Jay was talking about on the rear seal on the fe engines .
bsprowl
Sr. Member
Reply #5 on:
November 05, 2020, 09:54:32 PM »
I recall working on such a contraption when I hung around a carnival the summer I turned 18. That's wasn't our problem; the guy had welding issues.
