Author Topic: Ideal Flathead combustion chamber shape  (Read 29131 times)
allrightmike
Re: Ideal Flathead combustion chamber shape
« Reply #30 on: November 04, 2020, 01:55:07 PM »
HEO, your suggestion is exactly what Harley came up with called the high dome concept. raising the combustion chamber in a hemi shape with a matching piston with close quench. Gives a straighter intake & exhaust shot at the valves.
'60 Starliner 427 4speed.
Quisp21
« Reply #31 on: November 04, 2020, 02:11:33 PM »
The 337 is very underappreciated from a performance standpoint.  Remember, at the time, the 337 was competing directly against the OHV Cad 331 and was very comparable in power output (154 hp vs 160) and torque (265 ft-lbs vs. 292 ft-lbs).  That said, there is lots of room to improve.  I would start by studying the Harley Davidson KR engine.  Harley coaxed 60+ hp out of 45 ci in order to exploit a loop hole in the flat track rules at the time that gave flatheads a LARGE displacement advantage.  HD achieved this incredible 1.333 hp/ci with only 6:1 compression.  This would be perfect for a highly boosted application.  Imagine a 337 Lincoln with this same hp/ci ratio would produce 450 Hp!  The other place to look would be to get ahold of Rick Schnell up in Anoka.  He has the word's quickest flathead powered dragster.  The "Slider" is a 950 Hp+ Nitro huffing FED.  Obviously Nitromethane and a 4-71 blower will cover up a lot of sins, but I guarantee you Rick has a few flathead tricks up his sleeve.
https://www.youtube.com/watch?v=9-OXWC7Ufv4
https://www.cycleworld.com/flat-head-motorcycle-engine-examined-kevin-cameron-top-dead-center/
« Reply #32 on: November 04, 2020, 02:36:11 PM »
My ideas on this subject will be a bit different. I like the idea of FT pistons, with a enhanced, transfer area. Flow bench the transfer area to see what flows the best.
What I learned about fluid dynamics, say that the pressure will be equal, within any given space and that pressure will exerted by the square inch area, regardless of shape.
Flame travel is very different from pressure and I agree with moving the spark plug. I would put it on the edge of the transfer, angled to the cylinder. It's my understanding that Ford put it near the exhaust valve, to keep it clean but, with modern extended plugs, I don't think it's relevant now.
As for the valves and getting flow, since there is virtually no flow over the valve, you need to work with the curtain. Larger valves, have larger curtains so, I would install the largest valves possible at a 85% ratio and work the contour around them on a flow bench. Everything needs to be as tight as possible in the chamber but, give the transfer and the area around the valves, everything they need. i.e. min piston to head and min head gasket shape and min clearance for the valve head, to back of the chamber, to promote forward flow.
I would also use as large a radius as the top ring to top of the piston will allow, to gain flow in the transfer area.
« Reply #33 on: November 04, 2020, 02:38:20 PM »
https://www.jrracecar.com/engines/?sort=featured&page=18  zoom in on the relief work of the 3.5 bore block , I can't find a chamber side but it mirror's the block with enough clearance for .580 lift in the valve area , Outlaw Jr Dragsters are making 55 horse from a single cylinder 3.5 bore X 3.0 inch stroke and buzz 10,000 rpm , my own kids 7.90 et 3,5x3.0 will make 45 horse power and buzz 8500 rpm for 400 passes in a season back in the late 2000's
« Last Edit: November 04, 2020, 02:41:24 PM by e philpott »
« Reply #34 on: November 04, 2020, 02:44:05 PM »
This is what the FT piston, '34 - '36 Ford, aluminum head chambers and the '37 dome chamber look like.
« Reply #35 on: November 04, 2020, 03:29:29 PM »
« Reply #36 on: November 04, 2020, 04:01:04 PM »
Doug, im talkin about the area abow the piston.Raising it about the same as the relieve (1/8 or so) in the block
and have a piston that fill that area when at tdc. And leaving the area abow the valves"untouched. If Joel is
going to cast new heads he can probably compensate the ticknes abow the chamber
Now i see the harley head is somthing like what i was thinking. I notice the plug is centered over the exhaust valve
on them
The head you have pics of looks verry much like the german Wood gas head i have on the Model A
8.5 CR Made for the German Army during WW2
You know how astock A idles i think? with this head the idle became super smoth and you can idle it
down till it just tick over and gained a lot of low rpm torque topspeed became scary...not that it is that
fast in otherwise unmodified A ;D ;D
« Last Edit: November 04, 2020, 04:08:44 PM by Heo »
Hemi Joel
« Reply #37 on: November 04, 2020, 05:12:19 PM »
Barron offered a high dome head&piston design that used a full radius piston dome with a raised hemi shaped combustion which made for much improved breathing.He copied from a Harly Havidson design for flat track racing.
how high of a dome was at? Was it a partial hemisphere all the way around, or did it have any irregularities to the shape?
Hemi Joel
« Reply #38 on: November 04, 2020, 05:13:26 PM »
While Brent is right (there have been a couple of high horsepower flatheads built using that method), it's an extremely aggressive approach that requires an insane amount of work. The examples I saw also used a lot of epoxy, which I would not consider very acceptable for long term use.
If you're wanting a modern chamber design, this is about the only modern type chamber I've seen. This is an old head that you'll never find, but could be reproduced in a custom head. I saw this recently at the Early Ford V8 Museum. Can't say as I've ever seen anything that was more high tech than this for a flathead head.
One of the big issues is getting enough area above the valve to get good flow. If you open that area up, you lose not only compression, but much of the combustion pressure is wasted in the valve area. The head above seems to use a 'depression' from the valve area to the combustion chamber, to help promote that flow. It may not be the best design, but it's a sound idea that could be used in a custom head.
I hope you give some updates on this. This is the Non-FE area, so it fits here. :)
that's a really cool and interesting looking chamber. I wonder if it worked very well? It looks like it was designed to introduce swirl.
Hemi Joel
« Reply #39 on: November 04, 2020, 05:14:44 PM »
My answer would be to do all you can to unshroud the vales and even more important help the exhaust as much as possible. Give it an 8:1 open chamber. 20 psi of boost will cure a lot of design sins.. LOL  Find an old guy that runs a blown flathead on nitro.. See what they did..
having boost should eliminate the need for a very high compression ratio. Hopefully 7 1/2 or 821 will not to do occult to achieve.
Hemi Joel
« Reply #40 on: November 04, 2020, 05:15:24 PM »
Someone versed in fluid dynamics could probably created a pressure vs flow graph to estimate the point of diminishing returns. The import guys do 40 lb , but that's with a turbo..  A screw or centrifugal type blower should not heat up the air as bad as a rootes type
Royce, do you know someone versed in fluid dynamics who could figure this out for me?
Hemi Joel
« Reply #41 on: November 04, 2020, 05:18:33 PM »
I'd reach out to Ron Main and get some ideas from his group.  They had 700hp out of ~300cu/in.  http://speeddemon.us/flatfire.html
I have seen pictures of the flat fire engine with the heads off.  Landy built that engine and he moved all of the ports into the valley. That's more work and it depends on the block than I care to do.
Hemi Joel
« Reply #42 on: November 04, 2020, 05:24:57 PM »
I would give Ted Eaton a call. He is very innovative and has some real experience with the 239 FH. I don't know if he has ever worked with the 337 though but, he would be the first one that I would ask about this.
https://www.eatonbalancing.com
Ted is now on my list of people call, thanks very much!
Hemi Joel
« Reply #43 on: November 04, 2020, 05:26:04 PM »
Many years ago I looked into supercharging the 239.  The problem was getting the exhaust out of  those ports without over heating the engine.  The center siamesed ports seemed to want to boil the coolant.  Yes you could get a lot of combustible air into the engine, but it seemed to hit a early limit because the exhaust gas just couldn't get out.
Using an early opening valve to push the exhaust out just added to the coolant problem as the mixture wanted to burn in the exhaust port.
The 337 does have much better exhaust ports in the block then the smaller 24 stud flat heads.also the heat riser comes up to the intake manifold from the center exhaust port. That could be pretty easily converted into a fourth exhaust port. The front and rear exhaust ports can be shortened pretty easily by making a hole in the front and the rear of the block and hooking the header up there. That should reduce heating.  hopefully the problem can be overcome. This engine only needs to run for about three minutes at a time
Hemi Joel
« Reply #44 on: November 04, 2020, 05:38:24 PM »
thanks for the pictures of those heads, I like the looks of that and it is definitely something we could try. I will be getting a hold of Rick Schnell as well, thank you
