FE Technical Forum
406 Block Questions
Topic: 406 Block Questions (Read 4288 times)
C8OX-FE
Newbie
406 Block Questions
October 19, 2020, 01:21:05 PM »
Hey guys,
I have a 406 block that has been bored to 4.23, I'm assuming it will need 8 sleeves. I'm trying figure out what it's worth. Any help would be appreciated!
Ghoughton
Jr. Member
Re: 406 Block Questions
Reply #1 on:
October 19, 2020, 04:05:14 PM »
406 blocks are super thick. I have run them successfully at 4.23 bore, as have others. Even though it’s pushing the limits. I wouldn’t be afraid to run as is with no sleeves. However..... to answer your question about worth, I’d say $700 as is.
6667fan
Every Second Counts
Reply #2 on:
October 21, 2020, 06:47:12 AM »
What is the date on it? As mentioned, many were cast thick. If it still sonics well it could be worth double that or more to someone who is after a certain date for their full size Gal or Marauder.
JB
67 Fairlane 500
482 cid 700/617
TFS Tunnel Wedge, BP BBM Heads, Bullet Custom Solid Roller, Ram adjustable clutch, Jerico 4-spd, Strange third member with Detroit Locker, 35 spline axles, 4.86
10.55@125.74 1.46 60’
Lowrider
Full Member
Reply #3 on:
October 21, 2020, 08:44:10 AM »
I ran a 406 bored to 4.23 years ago on the street. Never had any problems with it.
427John
Sr. Member
Reply #4 on:
October 29, 2020, 12:29:41 AM »
So is the thick walls common to all 406's or just certain casting numbers?I'd heard that some late blocks were cast thick but didn't know if it applied to all of them.
FE Technical Forum
406 Block Questions
