Author Topic: Valve cover gasket questions  (Read 3209 times)
KsHighboy
« on: October 17, 2020, 04:54:27 PM »
My passenger vc is leaking and I have several old cork gaskets around. You guys think it would be advisable to use old cork? The gasket i have is an old, probably 15yrs old. Do they dry out over time or not? I wouldn't say it feels as new but its not brittle. If I need to go buy new then what gasket is best?
Re: Valve cover gasket questions
« Reply #1 on: October 17, 2020, 05:36:27 PM »
Cork does eventually go bad, but it usually dries out over time and breaks down.
With that being said, I only use cork valve cover gaskets.  Not a fan of the rubber ones.
« Reply #2 on: October 18, 2020, 01:38:24 AM »
If the cork is dried out the gasket is to small. You can soak it in hot water that way
it swell to the right size and gets more pliabel
