Author Topic: Been thinking about what I'd like to put the 352 in....  (Read 29329 times)
Re: Been thinking about what I'd like to put the 352 in....
« Reply #30 on: October 09, 2020, 10:46:03 AM »
https://killeen.craigslist.org/ctd/d/salado-1966-ford-ranchero-289ci-v8/7200168779.html
The best of both worlds.  I am sorely tempted to go look at this one for myself.  Joe-JDC
« Reply #31 on: October 09, 2020, 11:31:43 AM »
When I saw the subject line I immediately thought  '66-'69 Falcon.   Fairly light, different (like the 352 in it!) and an FE ready engine bay.   I believe Fairlane specific FE engine bay stuff will work, like headers.
Note:  Fairlane front end sheet metal supposedly bolts one, too.  I like the Falcon look, though.
pl
« Reply #32 on: October 09, 2020, 01:09:37 PM »
What does it entail to put an FE in it.
« Reply #33 on: October 09, 2020, 01:51:28 PM »
Fairlane motor mounts, transmission mount,  FE radiator, and transmission lines if using an auto with cooler, driveshaft, and I would install a 9" rear with at least 31 spline axles.  Just about anything that fits a mustang or fairlane that came with FE will cross over.  The motor mounts are a tricky part because of the offset for the through bolt, but again use a fairlane mount, and it bolts in.  Upgrade the front springs, sway bar, shocks, and you have a mustang in a falcon body.   Joe-JDC
« Reply #34 on: October 09, 2020, 01:52:09 PM »
My understanding, haven't done it, is that it's all the same as a '66-'67 Fairlane or Comet.  Same motor mounts and headers.  Someone correct me if I am wrong.
pl
MeanGene
« Reply #35 on: October 09, 2020, 03:50:12 PM »
Yeah, including shock towers. 57 has none
bsprowl
    • Ford FE Information
« Reply #36 on: October 09, 2020, 08:42:40 PM »
'66-'69 Falcons share the engine compartment with the Fairlanes-Comets of those years.  The Rancheros and station wagons share the same chassis but the rear springs are inset an inch or so. Any of the parts used to mount the FE in the Fairlane fits just fine.
urchinhead
« Reply #37 on: October 10, 2020, 01:33:16 PM »
Pickup Truck?
1965 FORD F-100 Twin I Beam STEPSIDE *TWO OWNERS *MINIMAL RUST *CA CAR
https://sfbay.craigslist.org/sfc/cto/d/monterey-1965-ford-100-twin-beam/7197538689.html
1964 Galaxie 500 Convertible, drivetrain on stand
1970 F100 Custom, 428 - body work and paint in progress
bluef100fe
« Reply #38 on: October 10, 2020, 08:24:57 PM »
Friend of mine has a 64 falcon with a 428 in it... full cage and it weighs 3200lb I believe with 150 lb driver
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
FERoadster
« Reply #39 on: October 13, 2020, 10:33:01 AM »
I've got this one sitting on my trailer to sell right now. Issue is I'm having an issue getting the title straightened out.
62,000 miles I last drove it in 1972 then have stored it since.
Richard >>> FERoadster
winr1
« Reply #40 on: October 14, 2020, 12:27:41 AM »
This ... but ya have to fly down to drive it ....  ;)
Ricky.
« Last Edit: October 14, 2020, 12:31:27 AM by winr1 »
driveamerican
« Reply #41 on: December 26, 2020, 02:17:07 PM »
Any bowtie.
wowens
« Reply #42 on: December 28, 2020, 06:35:06 AM »
I have a pretty solid and straight 57 Ranchero that need a new home. Was already a hot rod, got taken apart for paint and never finished. Had a souped early 390 4/spd in it, has tilt column and front discs. Stainless is there and chrome has been re-done. 57s make great hotrods- and hotrod shop trucks
Woody
62Falcon390
« Reply #43 on: December 28, 2020, 10:51:17 PM »
early 60s Falcon.. mines 3380 pounds though but i made it overkill
« Reply #44 on: December 31, 2020, 07:10:52 AM »
My '72 Pinto weighed 2240 complete with a full tube frame and cage, and an all iron 466 SCJ and a C6 and 9" Versailles rear axle. 1140 was on the back tires. (345-35 Pirellis on 12 inch Weld wheels. Used 285-40s on the front). Had a 4" chopped top.
