Author Topic: Guess the oil leak?  (Read 8578 times)
fairlaniac
Guess the oil leak?
« on: August 30, 2020, 06:53:45 PM »
I need this for therapy :-)
My self built 47(484) would leave a drop or two (dime size) oil leak under the bell housing shortly after my first start. It was frustrating but these things can happen. Then it didn't take long until it was a quarter size and now about 150-200 miles on the new build the oil slick is now a 3" diameter spot. So I figure in a month or two (over winter) I'll pull the trans, bell, etc... However I am trying to diagnose what it may be. I brushed it off as a rear main seal issue. However the oil appears to form a line at the trans and scattershield and drips forward down the slope of the scattershield and down the vertical bolt flange then to he ground. I also am getting drips from the back side of the fork onto my headers. I'm trying to figure out what could cause oil to get past the flywheel & clutch onto the fork. I can start the car and the oil will develop in 5 minutes. I'm use to seeing main seals drip in front of the flywheel and block plate and drip down. It baffles me how oil gets to the transmission front flange?
Here are some pictures of the leak if you can make them out.
Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
SSdynosaur
Re: Guess the oil leak?
« Reply #1 on: August 30, 2020, 07:17:44 PM »
Have you positively identified the leaked product as engine oil because your tracing description sounds like trans input retainer gasket and/or bolts leaking trans lube.
fairlaniac
« Reply #2 on: August 30, 2020, 07:21:17 PM »
I've put dye in my engine oil and on a black light the spot on the floor lights up.
Doug Bender
1978 F150 2WD 390
« Reply #3 on: August 30, 2020, 07:23:50 PM »
I agree I don’t think it’s oil. Not leaking from there. Input shaft gasket-or a crack-or bolts loose. Main shaft seal leaking. I don’t see how it could get that high to leak in that spot
GerryP
« Reply #4 on: August 30, 2020, 07:26:07 PM »
Most of the time, it's the valve covers or the rear China wall.  It's doubtful it's the rear main since you get a lot of oil out of that.  See if your dye shows up at the rear of the engine.
fairlaniac
« Reply #5 on: August 30, 2020, 07:58:34 PM »
Doug Bender
1978 F150 2WD 390
« Reply #6 on: August 30, 2020, 08:23:55 PM »
Now you can see it coming around from that pic.
fairlaniac
« Reply #7 on: August 30, 2020, 08:28:10 PM »
The dye is in the engine oil.
Doug Bender
1978 F150 2WD 390
« Reply #8 on: August 30, 2020, 08:46:13 PM »
I'm with Gerry, check the rear China wall. Try to get a mirror back there.
« Reply #9 on: August 30, 2020, 10:12:35 PM »
valve cover leaks can travel to other areas
fairlaniac
« Reply #10 on: August 31, 2020, 06:11:43 AM »
Thanks but I have checked the obvious leaks externally. It would be difficult for oil to drip from the China wall and get inside to the point where the T/O bearing is mounted on the fork. As indicated, I have oil coming down the back side of the fork and dripping on the header.
Thanks,
Doug Bender
1978 F150 2WD 390
Gregwill16
« Reply #11 on: August 31, 2020, 06:20:56 AM »
If definitely inside the bell, may be one of the plugs or the relief valve in the rear of the block.
fairlaniac
« Reply #12 on: August 31, 2020, 08:34:16 AM »
That's what I'm hoping. Easy fix.
Doug Bender
1978 F150 2WD 390
« Reply #13 on: August 31, 2020, 08:21:08 PM »
I would still guess valve covers. Before putting the aluminum ones on my Fairlane i fought that with the chrome valve covers. Was damned sure it was the rear main seal... but that didn't fix it. Took the intake off and resealed that (used cork ends this time)... nope, after having the bellhousing off a second time (and headers to get it off) i noticed a very slight wet trail on the back of the head. The valve covers leaked and dripped off the middle of the bellhousing. Sure felt dry from above when i'd checked.
fairlaniac
« Reply #14 on: August 31, 2020, 09:09:14 PM »
Tom, from under the car while on the lift I can see clearly to the heads and there is not one drop of oil from the valve cover. With a penlight black light and mirror. I can see the dye light up inside the bell and all the way up to the t/o bearing on the fork.
Doug Bender
1978 F150 2WD 390
