Author Topic: Guess the oil leak?  (Read 8579 times)
JERICOGTX
Re: Guess the oil leak?
« Reply #15 on: September 01, 2020, 08:05:15 AM »
With a block plate, it's odd that engine oil would be getting into the Scattershield. They are pretty much sealed off to the engine. I had/have the same issue on my car, and figured out that it's the input shaft seal, in the throwout bearing collar, on my jerico transmission.
shady
« Reply #16 on: September 01, 2020, 08:49:06 AM »
Some plates have holes for gallery plug plus the big hole for the cam plug which are all above the crank throwing oil everywhere.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
6667fan
  • Every Second Counts
« Reply #17 on: September 01, 2020, 09:10:18 AM »
If it is the galley plugs the migration is extreme. The clutch will be risking oil contamination. Any oil on the engine side of block plate?
The galley plugs have a dedicated pitch to them. Other plugs will work but an extreme sealant like Blue Block is what I like for sealing those.
I’m glad you think ripping the trans/clutch down is easy, lol. At least you have a lift and a trans jack/support I hope.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #18 on: September 01, 2020, 09:36:24 AM »
^^This...
As far as I know, all the Lakewood plates have those holes, and they will allow oil to be slung around and past those holes. And yes, if that happens, it will ruin a clutch plate within a fairly short time period. If Doug is sure that the oil is from the back of the engine, and he has a Lakewood plate, or similar plate with holes, then it would be wise to get it fixed as soon as possible. Although I'd certainly make sure that was where the source was from, because I hate pulling transmissions.
Edit to add that I have no idea why Lakewood put those holes there. You can't reach the plugs with the flywheel in place, and if the flywheel is off, there is nothing holding the plate on. Makes no sense to me.
« Last Edit: September 01, 2020, 09:39:29 AM by cjshaker »
HarleyJack17
« Reply #19 on: September 01, 2020, 10:26:06 AM »
Most likely it is oil galley plugs or cam plug.
BUT, isn't there the off chance that the plug in the crank could cause an oil leak as well?
fairlaniac
« Reply #20 on: September 01, 2020, 04:38:50 PM »
Jim, I've got the lift and last year at Maple Grove's swap meet my buddy picked up a trans jack/support that I can use. I say easy fix because those are the games I must play with myself when motivation fails :-)
Today I ran the engine while the car was up on the lift and watched the oil. It ran down the front of the block plate and the mating surface of the bell and trans.
I won't be bringing the Fairlane to FERR next week. I'll pull the trans and bell after that.
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
