Author Topic: 390 Build  (Read 10959 times)
aarons428
390 Build
« on: August 26, 2020, 09:47:45 AM »
I'm working on a guys 54 f100 that someone swapped in a 390. I got a 67 390 out of a car that he wants me to get rebuilt and wants to have a "strong 400hp" out of it. What would you guys suggest for parts to get me to that point? Please no negative comments I've tried asking on facebook and they just suggested going to a windsor but obviously I'm not doing that.
Thanks for the help!
It does have block hugger headers on it already. I do know he wants it to sound healthy but I know that doesn't mean a whole lot. It will be more of a toy than a daily driver.
With out porting what can 67 heads handle?
« Last Edit: August 26, 2020, 12:49:30 PM by aarons428 »
65 f-100 swb
428 4v
c-6 trans wide ratio
3000 stall converter
torino front stub
latter bar style rear suspension w/air bags
11.96@110mph
Re: 390 Build
« Reply #1 on: August 26, 2020, 10:07:44 AM »
Lots of ways to get there. You might want to let us know what kind of budget this has, and how much of the 390 engine you want to retain, for example are you keeping the cast iron heads? Also, since this is already an engine swap - does it already have headers? Does it have to use stock exhaust manifolds?  Edit to add, probably want to let us know how they are going to use it ( daily driver or just occasional toy ), how “rowdy” do they want it, or how much will they tolerate? Etc.
« Last Edit: August 26, 2020, 10:28:07 AM by thatdarncat »
Gaugster
Re: 390 Build
« Reply #2 on: August 26, 2020, 12:32:52 PM »
Be sure to comb through the dyno results forum to gather some ideas. Why does he want 400HP? Is is 400HP at the crank or wheels? A comment like "Strong 400HP" makes me think a high torque down low application but it leaves so much up to interruption. Here's a partial list of considerations and things you need to learn from your guy. Some of it repeats from the prior post.
Budget?
Driving style?
What transmission and rear end gearing is planned?
Is good vacuum at idle and light cruise needed for accessories?
Desired RPM maximum limit?
Premium fuel only?
Good luck!
« Last Edit: August 26, 2020, 12:34:50 PM by Gaugster »
SMA390
Re: 390 Build
« Reply #3 on: August 26, 2020, 04:16:23 PM »
definitely get a budget to start and work from there. If it needs  bored out, I would look at a stroker kit from Barry, a performer rpm manifold , updated ignition ( MSD box ) good valve job and maybe clean up the heads some unless there is money for after market heads. If you had money for heads I would just get with one of the builders here and buy a set ready to bolt on, you have headers so I would run 3" open exhaust straight out no mufflers I would get a cam from one of the builders here that will match the other parts and based on any vacuum accessories, that would definitely push you over the 400 hp mark..
You could also check out Jays article on his web page for Car Craft.. it has good info and parts on  390 build like your wanting
chilly460
Re: 390 Build
« Reply #4 on: August 26, 2020, 05:28:23 PM »
I'm going to make some assumptions based on what you're saying.  I'm thinking a truck like that is going to be around 3700lbs, and he'll be OK with at least a 3.50 gear and 2500rpm stall.  This is still pretty mild but a notch above "daily driver".
If it were me spec'ing it, I'd go with 750cfm Holley, Performer RPM intake, TFS heads, rebuilt stock rods with ARPs, stock crank, and an Autotec piston, get it somewhere around 9.5:1 compression.  If he has it in the budget, hydraulic roller in the 224/230  .550-.575"  on a 110lsa.  It'll make well over 400hp, tons of low and midrange, and it'll have enough sound to be cool at cruises.
Any iron head is going to need a full rebuild, and at least some bowl cleanup and likely larger valves to support an honest 400hp without putting a good bit of cam in it.  If that's the case, to me it makes sense to jump right to a TFS.  You get excellent ports, modern chamber, hardened seats.
Performer RPM is no brainer for a build like this.
Roller cam is definitely a luxury at this level but alleviates startup concerns, doesn't require fancy oils, and will help make use of the good heads.
Combo like this would absolutely scoot in an old F100
FERoadster
Re: 390 Build
« Reply #5 on: August 26, 2020, 07:16:22 PM »
I'm of the really budget rebuild class of person.
First off I'd go with a 428 crank and then see what Jay's book says about a F-427 or another dual plane, headers. Single plane such as a POS or Street  Dominator might not meet his goals. To me EDEL. RPM 's are the new belly button (sic.) such as a SBC. Things can be more reasonably priced.  Heads will cost near $2000 so look for a set of CJ or possibly 427 LR heads. Cost will be about 1/3 less than Trick flow or Edelbrock RPM heads.
On a budget to get 400HP and torque he needs for a 54 Ford PU he'll be happy. I'd gear with a 3.50 or 3.70.  3.70 will get you  with taller tires that fit the fenders better.
Richard >>> FERoadster
PS:
Also as 410Bruce decided in his post >>> run with what I have.
« Last Edit: August 26, 2020, 11:01:28 PM by FERoadster »
hwoods
Re: 390 Build
« Reply #6 on: August 26, 2020, 09:09:17 PM »
Recipe from a shop in Houston  claim 350-400 HP
390 block bored, honed, decked and align honed
Performance camshaft:
214/214 @ .050
.490 lift
110 lobe center
New performance cam bearings
Balanced rotating assembly with balancer
Reground 3.78" stroke crankshaft
Resized rods with ARP® rod bolts
New performance bearings
Performance pistons with Molly® rings
10 to 1 compression ratio
New performance timing set
New performance high volume oil pump
Cylinder heads
2.06"/1.66" stainless steel valves
110 lbs valve springs
3 angle seats
bronze guides
positive seals
Reman rocker arm assembly with new shafts
New performance gasket set
Painted Ford blue or gold
Bowl porting
Stage 2 porting ( Add $ 795.00)
Dial in cam
Price $ 3999.00 exchange or a $ 400 core charge plus shipping
Re: 390 Build
« Reply #7 on: August 26, 2020, 09:44:37 PM »
It was said before but really the number means nothing, you need to sit down with the guy and find out what he expects, what he doesn’t know, what you can teach him, and then come up with a plan with a good budget in mind.
Most of my planning for engines for other people takes more time discussing what they think they want and coming up with some thing that will really work well for them than the assembly.
 There should be no surprises when the engine delivers. Good thing is 400 hp is pretty easy, but everything from vacuum For power breaks to what the idle will sound like , all matters to these guys. 15 ways to Sunday to make 400 hp so good easy start, but find out how the truck will exactly be used, build for tha,  and you will be his hero
aarons428
Re: 390 Build
« Reply #8 on: August 27, 2020, 09:20:07 AM »
I just remembered he has a 66 Impala SS that has a ZZ427 crate motor which runs about 480hp/490ftlbs so he knows what to expect. I will talk to him soon on budget and expectations.
65 f-100 swb
428 4v
torino front stub
11.96@110mph
chilly460
Re: 390 Build
« Reply #9 on: August 27, 2020, 09:40:17 AM »
Guess it all depends what he expects, if he wants it similar to that crate 427, that will be more than a casual build for a 390
WerbyFord
Re: 390 Build
« Reply #10 on: August 27, 2020, 10:29:56 PM »
The ZZ427 Rat is a nice combo - only $13,000, and with a warranty.
If that is the level your friend wants, it's pretty easy with an FE.
EE427 Recipe
(Ford equivalent of Chevy's ZZ427)
4.233 x 3.784 427 FE
Edelbrock heads, just cleaned up so they flow like they did box stock in the 1990s before 2% inflation hit.
Barry R used to do this.
Ed RPM intake, similar intake to ZZ427
780 Holley, same carb as ZZ427
Same cam as ZZ427, hyd roller
224-234-110 ICL=110 .527 .544 lift
10.1 CR same as ZZ427
2" dyno headers, same as I used to match the ZZ427 Dyno test
Truly an equivalent Build to the ZZ427
I even painted the Gonkulator version orange. Ok, no.
Torq 494 at 4100
Powr 485 at 5500
Again, truly the equal of Chevy's ZZ427.
There are better FE heads (as there are better Chevy heads) but the FE holds up pretty well against this Rat.
Your buddy's little tryck is likely a lot lighter than that fat 66 Impala (they got fat after 1964) so should make for some good clean fun.
NOW - as for that FE 390 with C7AE-A Tiny Port stock unported heads, and 400hp? That will be tougher.
As for that one, looks like it's not THAT hard. I actually just took the EE427 above and changed it to a 396, swapping heads:
4.08 x 3.784 396cid
c7ae-a heads, bone stock with 5-angle valve job
Ed RPM intake
780 Holley
10.1 CR
224-234-110 .527 .544 hyd roller cam, same as Ford EE427 and Chev ZZ427 above
2x33 headers
Surprisingly, this Gonkulated to
Torq 426 at 4000
Powr 400 at 5400
Of course with better heads you could do much more, but there's your 400hp if that is the goal.
On the dyno anyway - the block hugger headers might eat a few ponies.
« Last Edit: August 27, 2020, 10:58:39 PM by WerbyFord »
Re: 390 Build
« Reply #11 on: August 28, 2020, 02:18:59 PM »
This is what I get with a CC, 224/234-.524x.574 HFT (5433/5446 lobes) and a good bowl blend, C1AE, 2.09x1.65 head. 259x205 cfm @ .500, from Stan Weiss site. 750 cfm x 180 manifold. 9.99/1 CR. 1.81 x 14.5" shorty headers
« Last Edit: August 28, 2020, 02:24:58 PM by frnkeore »
chilly460
Re: 390 Build
« Reply #12 on: August 28, 2020, 02:41:56 PM »
BTW thanks to Barry for posting this stuff, I can't find too much in the way of these more "basic" 390 builds as far as dyno results.
Edelbrock package with a cam larger than what we're discussing just eeks out 400hp.
https://www.youtube.com/watch?v=EpD7fpKWpXw
Cleaned up stock heads with CJs doesn't get there
https://www.youtube.com/watch?v=PjxO7sND__Q
Doesn't get there again with CJ valved D2TEs
https://www.youtube.com/watch?v=iFFGDqQpx2E&t=47s
Doesn't get ther again with iron heads but similar other parts
https://www.youtube.com/watch?v=DzKo8nKDoCk&t=11s
Edelbrocks and a 230* once again eek over 400hp
https://www.youtube.com/watch?v=ftQzzTis4iE&t=24s
This edition of Ebrocks and a 280H didn't get to 400hp
https://www.youtube.com/watch?v=zPxUNbXov_Y
Ebrock topend and a 270H well under 400hp
https://www.youtube.com/watch?v=dXPaAkaPBAM
I see references all the time to combo requests, declaringe you throw a 750 and a small flat tappet and headers on a 390 and it's a 400hp deal, and that's just not the case.  I ran a 390/750/Perf RPM/bowl blended Edelbrocks/270H/headers....it just wasn't that strong.  It's still not "fast" but the BBMs and 224* Survival roller with some plenum work woke it up a ton, and would be the minimum I'd run if I was trying to make a customer happy.
« Last Edit: August 28, 2020, 02:53:23 PM by chilly460 »
Re: 390 Build
« Reply #13 on: August 28, 2020, 03:11:31 PM »
Talk to the guy :)
I own a deep breathing 489 Mustang, but built my truck to peak at 5000.  That Chevy discussion is all speculation.  Pick his brain, strong 400 HP doesn't say ANYTHING, need power brakes?  Need some chop in the idle, HATES chop and wants smooth idle?  Wants gas mileage, wants it to spin 6000 RPM? Any chance for EFI later?  Overdrive?  A zillion questions
Easiest thing to do is to work out what he expects, then build to it or more as long as it matches the personality he wants.
« Last Edit: August 28, 2020, 06:56:17 PM by My427stang »
Re: 390 Build
« Reply #14 on: August 28, 2020, 05:35:42 PM »
The above engines, appear to be almost identical. Maybe Barry could fill us in, on what is different?
On the Stan Weiss site, the out of the box Edel's flow,  the same as the bowl ported C1's with CJ valves but, the C1's flow a little more on the Ex.
With a FT cam, it appears that you need about 230 @ .050 to make 400 HP.
