Author Topic: Various FE Parts, '69 Mustang Parts  (Read 4428 times)
CV355
« on: July 26, 2020, 03:57:43 PM »
I have the following parts available for sale, all of which came off a 1969 Mach 1, 428CJ, Q-code car.  All components are functional, many of which have less than 2000mi of use:
'69 Mustang Parts:
OEM Brake Master Cylinder and Bendix Dual 8" Booster, Prop Valve:  SOLD
Stock Replacement Radiator, copper/brass (needs a flushing):  $120
Scott Drake Radiator Bracket Set (2x lower, 1x upper):  $30
OEM Steering Gearbox, (needs a rebuild, for those who may be interested):  SOLD
Re-mfg Hood Hinges, Steel:  SOLD
Export Braces, Chrome, Reman:  $45
Re-mfg, LNIB Windshield Washer Pump/Reservoir:  SOLD
'69 20g Gas Tank, does not include sender, repro:   $100
Gas tank has Second Skin Damplifier Pro installed on top surface
FE Parts:
OEM Water Pump, Ford Corporate Blue (comes with v-belt pulley):  $30
OEM Starter, C6, LNIB:  $40
OEM-style alternator, re-mfg, 4-wire:  $40
Flex-A-Lite Fan and Spacer:  $30
Hayes/Stinger Ignition System, Coil, HEI Hall-effect Distributor:  $150 (no documentation is available, but is totally functional)
Mangled OEM Oil Pan:  Free plus shipping
Prices are OBO, excluding shipping.  PayPal is ok.  I can provide plenty of seller/buyer feedback if needed.
I also have a C6 transmission, but I don't have specifics on it other than it has a 2800rpm stall converter with anti-balloon plate, Freddy Brown reverse manual valvebody, B&M finned aluminum pan.  It does have a cracked bolt ear which needs to be repaired.  Everything is functional- it must be a built transmission as the previous owner used it for drag racing, shifts very firm, no mechanical issues.  I decided to buy a brand new transmission instead of rebuilding this.  If anyone is interested, send me a message, not sure how to price this one but I promise it will be a deal...
« Last Edit: August 03, 2020, 07:29:32 AM by CV355 »
sixty9cobra
Re: Various FE Parts, '69 Mustang Parts
« Reply #1 on: July 27, 2020, 10:29:18 AM »
I am interested in the fan shroud and not the fan looking for a clutch fan will you separate?
CV355
« Reply #2 on: July 28, 2020, 10:26:31 AM »
Hello, I can.  Just shoot me an offer, I probably wont turn it down.  Just bear in mind that shipping costs are not included, but I can usually get pretty good rates.
sixty9cobra
« Reply #3 on: July 28, 2020, 12:39:40 PM »
hows 25 bucks? Shipping quote to 11766
CV355
« Reply #4 on: July 30, 2020, 06:57:08 AM »
Updated
Blueoval77
« Reply #5 on: July 31, 2020, 04:22:18 PM »
PM Sent
