Author Topic: 1961 Thunderbird 390...  (Read 45549 times)
stubbie
Re: 1961 Thunderbird 390...(and another GTH game...)
« Reply #45 on: August 22, 2020, 08:06:52 PM »
A 1" spacer would be good as a lot of birds suffer from heat soak. The spacers are angled also.
« Last Edit: August 22, 2020, 08:17:50 PM by stubbie »
wayne
« Reply #46 on: August 22, 2020, 10:00:59 PM »
I had a 390 out of a bird like that years ago in a 69 ranger pickup put a small crane cam 300- 500 or something like that.Stock iron cj intake headers and a 3310 -780 holley it ran real good.A friend had a chevy 1/2 ton with a 396-325 with headers it could bust his butt with  half a load of wood in it. This will be a fun build to watch.
« Reply #47 on: August 23, 2020, 05:13:06 AM »
Gonna try and dyno it next week to get a baseline.  New intake manifold will be here Tuesday, so I may even try and swap it on the dyno to see what difference it makes.
« Reply #48 on: August 27, 2020, 08:23:55 AM »
Dyno'ing the "before" on Monday.
philips66
« Reply #49 on: August 29, 2020, 04:09:22 PM »
Brent glad the intake will work for you.  Hopefully it was packaged good enough to survive the journey.
64gal482
« Reply #50 on: August 29, 2020, 04:24:20 PM »
My guess is 261 as is
Jose
« Reply #51 on: August 29, 2020, 04:38:09 PM »
It would have survived Nagasaki the way it was packaged.
WerbyFord
« Reply #52 on: August 29, 2020, 11:19:44 PM »
Don't forget the 1" 4-hole spacers on top, both those old intakes like that.
Maybe even try a fancy cloverleaf high-dollar spacer or something.
Plenty of room under most hoods for the spacer on those.
Good luck Brent!
« Reply #53 on: August 30, 2020, 06:58:33 AM »
Good luck Brent!
I don't think I own any 4 hole spacers.  I will try a Super Sucker though.
This thing is a complete variable.  Have no clue what's gonna happen LOL
Got new plugs and an MSD in it, filled it with oil and primed the pump.  We will see.
wayne
« Reply #54 on: August 30, 2020, 09:01:11 AM »
WerbyFord do you know how much a t bird 3x2 intake gives up to a full size car 3x2 setup.I think it is flat and dont have a rise front to back i had one years ago and sold it to the t bird store (now npd).I know it had a fitting under the center carb for power brakes.Not much i am sure but some i would think.
« Reply #55 on: August 31, 2020, 02:56:53 PM »
It was rebuilt by the "Proformance" guys in NJ.
In that case, I'd be surprised if it survives the dyno pulls. Those guys strike me as snake-oil salesmen.
Doug called it.  Couldn't even make a pull on it, got it up and running and the thing was so noisy we shut it down.
I got it home and stripped some of it down.  Cam was trashed and it wasn't because the lobes were wiped, it was because there was a problem with the installation so that lifters were contacting adjoining cam lobes.
So this is a '61 engine that did not come with a thrust plate.  However, when I tore it down, it had a spring/button that was located on the cam bolt.  One-piece eccentric, with a newer style cam gear.
I'm a newbie to these old style setups, I don't recall seeing one before.  Did the original old style camshafts have anything different on the front of them?  This one has a typical nose like I'm used to seeing.
« Reply #56 on: August 31, 2020, 03:06:51 PM »
The Earlier cam is different in the nose if memmory dont fail me
« Reply #57 on: August 31, 2020, 03:24:25 PM »
Should be a washer in there too I think.  This one didn't have it.
Royce
« Reply #58 on: August 31, 2020, 03:47:56 PM »
Brent when you redo it chuck the old cam hardware drill the block for a thrust plate, and proceed as normal.  That is not the first 390 to suffer from old and new parts mix..
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #59 on: August 31, 2020, 04:01:50 PM »
Its hydraulic roller cam came in the other day but was hoping to get a nice before/after dyno session.
Had already planned on converting it.
