Author Topic: Lykins Motorsports 445FE With Trick Flow Heads  (Read 8030 times)
« on: July 21, 2020, 06:30:38 PM »
Performance Summary:
      Cubic Inches:    445           Dyno brand: Stuska
      Power Adder:     Nope          Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  536
      Peak Torque:  575
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 390 block, 4.080", 10.150"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4.250", 9000 series
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat I-beam, 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle, forged, 18cc, 10.3:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 125M, 8-7200CH, Durabond F33
   Piston rings brand, size, other notes:  Mahle, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling HV, ARP drive, Kevko pickup
   Oil pan, windage tray, oil filter adapter:  Kevko copy of 15-850 Canton, no tray, repop oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Lykins Motorsports hydraulic roller, 231/235, 113 LSA, .630"
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet, factory cover
   Cylinder heads brand, material, port and chamber information:   Trick Flow, aluminum, OOTB port work, 69cc chamber
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  2.190", 11/32", 5.500"
   Exhaust valve brand, head size, stem size:  1.625", 11/32", 5.500"
   Valve springs brand, part number, specs:  PAC dual spring, 150/400
   Retainers and locks brand, part number, specs:  Crane steel retainer
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports non-adjustable roller tip, 1.76
   Rocker shafts and stands, brand, material:  Harland Sharp HD, Precision Oil Pumps stands and spacers
   Pushrods brand, type, length:  Trend, 5/16", various lengths
   Valve covers, brand, type:  Polished Aluminum with "390" Lettering
   Distributor brand, advance curve information:  MSD Pro Billet, all in by 2800
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Tuff Stuff aluminum
   Intake manifold brand, material, porting information:  Edelbrock Performer RPM, divider modification
   Carburetor(s) brand, type:  Quick Fuel HR-780
   Exhaust manifolds or headers brand, type:  2" tube dyno headers
Sand hauler
Re: Lykins Motorsports 445FE With Trick Flow Heads
« Reply #1 on: July 21, 2020, 08:21:58 PM »
Very impressive  :D
Bobby-   Carlsbad, NM
Twinibeam66
« Reply #2 on: July 22, 2020, 09:15:22 AM »
Awesome build Brent ! Just wondering what kinda max RPMs did this build turn ?
Thanks Twinibeam66
« Reply #3 on: July 22, 2020, 09:18:29 AM »
It peaked the horsepower at around 5500-5600 but we spun it to 6200.
« Reply #4 on: July 22, 2020, 09:59:01 AM »
Twinibeam66
« Reply #5 on: July 22, 2020, 10:14:31 AM »
Ok thanks Brent , be a great street engine !!!
