Author Topic: 428 CJ +.030 Old School freshen up statistic for those who wonder about stock.  (Read 8782 times)
Stock 9d block, 9c heads and 9c iron intake.
Old +.030 with quick hone and new rings
Stock rods, crankshaft, new bearings
No porting on heads and intake, stock
Fresh valve job but re-used everything, springs, valves, retainers, etc. but new seals.
HFT stock replacement camshaft with stock pushrods, non-adjustable rocker arms.
60 psi oil pressure, stock pan with windage tray.
Dyno headers, 750 VS dyno carb, stock ford points distributor.
Ran the engine at 2000 rpm to seat the rings, put 200 lb/ft torque on engine for several minutes and varied to 3000 rpm to make sure everything was seating in properly, set timing at 37* and made a short pull.  Everything looked good, so it was let cool down and heat soak.
Made another pull from 3000-6000, and checked it over, no leaks, no smoke, and it sounded just like a stockish 428 CJ should.
Set timing to 38* and made a second pull, and power came up, and torque was up a couple, so it was deemed ready for customer.
PS, got the dyno sheets reversed.  Sorry.  Joe-JDC
« Last Edit: June 10, 2020, 12:06:36 PM by Joe-JDC »
Pretty cool.
I know that a mild hydraulic roller and some Ferrea valves will pick one up to about 425hp/460 torque.
Joe, I'm interested in the cam you used. Does somebody make a 100% match factory CJ cam?
Stock points distributor?  What?  Oh, the humanity!!!  LOL!
The grief I get for running a Unilite conversion in my old dual point tach drive mallory!  I don't see the need for a $300 MSD distributor.
Lunati hydraulic flat tappet camshaft for power brakes, power steering, smog equipment, stock cast iron exhausts, etc.  10330211 262/272, 207/217 @ .050", .507/.533 on 112/108.  Very mild camshaft on purpose.  Peak torque at 3300, peak horsepower at 4800.  Actually would work well in a truck.  LOL.  Did not have a problem at 6000 rpm, but started falling off fairly quickly after 5500.  Going into a R code restoration that will only be driven to owner's private museum, and then all liquids drained and vehicle put on display.  No need for HIGHER performance.   Joe-JDC
TwoFifty
Thanks for posting.  Nearly identical numbers and in the same spots compared to the stock rebuild in our family Mach 1 from years ago.
I'd have to dig out the dyno sheets, but it was interesting to see that in our case (25 years ago) it was run with both dyno headers and CJ Mustang exhaust manifolds with very minimal losses switching back to the manifolds FWIW for those curious (I think it was under 10 hp loss).  Likely due to the relatively low peak RPM needing less airflow?
Dad always said it was a "great dump truck motor".  You had the same comment which made me laugh and prompted me to post and share!
Also almost exactly what a stock 428CJ made on my dyno, but the one I ran used stock 428CJ exhaust manifolds.  I'm surprised that the headers didn't help it more...
Looking at the average HP numbers, they are very close to Fords rating. Always said to be low. I'm wondering if Ford used average HP when they rated it. So, if they where push about it, they would have a real criteria, for doing so.
I had always assumed that they had just picked a number, just to get it in a better NHRA class.
WerbyFord
The Gonkulator sees about 20hp more in there, about 10 extra from the cam (vs the 428CJ) and 10 extra from the headers (vs iron CJ exhaust).
I wonder, were there mufflers at the end of the dyno pipes?
Yes, to mufflers.  Remember, I didn't do any tuning or spacers, etc., just broke it in, and made a couple of pulls to verify everything was working properly, and no leaks.  I would have liked to change timing more, different carb, different headers/exhaust manifolds, spacers, and of course I would have ported the heads and intake, better camshaft, but this is going into a museum display vehicle that will be parked for years.  Joe-JDC
Made 5 more dyno pulls with fresh stock 735 Holley, and fresh distributor with pertronix conversion.  371.7 Hp, different day, different weather conditions, etc.  Engine is back in car, headed to museum.  Joe-JDC
I have done several of them that come in right around that range.  And I always get people asking why so low compared to the internet rumors of 385-400 or more
