Author Topic: 482 TF heads,solid lifter cam, for My 58 custom 300.  (Read 14164 times)
FEDER
« on: May 26, 2020, 08:21:16 PM »
Just got it back. A VERY BIG thank You to Brent Lykins. He recommended the molnar rods,racetech pistons and speced  out the cam for Me. Every time I ordered parts they came within a week. And every time I called He answered. I live in WA State so that’s pretty damn good to get stuff that soon.so here’s the sheet 672 HP 572 TQ   HP at 6700 TQ at 5500. It won’t let me post the sheet wrong format.
351crules
Re: 482 TF heads,solid lifter cam, for My 58 custom 300.
« Reply #1 on: May 26, 2020, 08:46:45 PM »
is there a built thread somewhere?  awesome numbers
chilly460
« Reply #2 on: May 26, 2020, 09:09:45 PM »
Would take a bit of cam to get that hp peak, 265* or so?
« Last Edit: May 26, 2020, 09:50:14 PM by chilly460 »
475fetoploader
« Reply #3 on: May 26, 2020, 10:53:43 PM »
Whereabouts in WA state do you live?
1967  519 c.i.  TKX 5 speed
FEDER
« Reply #4 on: May 26, 2020, 11:40:02 PM »
1964 block,scat steel forged crank,molnar rods,racetech pistons. 30 cc dish pistons 2 thousand above deck.comp solid lifter cam 588-610 lift dur at 50 intake 242 exhaust 250. Trick flow heads out of the box. Blue thunder MR 2x4 intake with 750 vac secondaries. Carbs came with 72 primary jets dropped to 69s. 0.40 cometic  head gaskets. MSD dizzy light spring black ring. I did mill 240 thou off the rocker stands. Rockers are rocker arms unlimited stainless rockers. Timing at 30 degrees.
« Last Edit: May 26, 2020, 11:54:13 PM by FEDER »
wcbrowning
« Reply #5 on: May 26, 2020, 11:56:05 PM »
What is the static compression ratio of your engine?
FEDER
« Reply #6 on: May 26, 2020, 11:56:43 PM »
I’m in Stanwood
475fetoploader
« Reply #7 on: May 27, 2020, 12:41:02 AM »
Cool, I live in Puyallup.
« Reply #8 on: May 27, 2020, 07:31:03 AM »
Looks to be just over 10:1 to me
badcatt
« Reply #9 on: May 27, 2020, 11:12:31 AM »
I’m in Stanwood
I'm on Camano Island. Have you had your 58 to one of the Twin City Idlers shows? I recall seeing one a few years back.
FEDER
« Reply #10 on: May 27, 2020, 12:51:06 PM »
Haven’t had in the show was parked outside the gate.
badcatt
« Reply #11 on: May 27, 2020, 12:59:38 PM »
I is sad that we had to cancel it this year. It really brings a lot of cool cars to town.
from the 2018 pre-show cruise.
Not mine; but this was so much fun to watch until it got out of hand.
« Reply #12 on: May 27, 2020, 10:15:32 PM »
Just curious what is a safe horsepower for a stock block. Obviously S/Stockers have like 8 or 900 but are those stock blocks.
KjcfeF100
« Reply #13 on: May 28, 2020, 09:37:47 AM »
Quote
Is that cam a solid flat, or a solid roller?
« Reply #14 on: May 29, 2020, 06:36:06 AM »
It's a solid flat tappet.
