Author Topic: BP Truck Application 469FE  (Read 24436 times)
Re: BP Truck Application 469FE
« Reply #15 on: May 19, 2020, 11:05:24 AM »
Holy Moly that's impressive !!
HarleyJack17
« Reply #16 on: May 19, 2020, 11:41:15 AM »
The owner may need to upgrade some drive line parts to hold all that as previously stated. They are tough old trucks for sure, but that is some serious new level power down low. Still cheaper than a new one, and you can work on it with out a puter science degree. Well done, two thumbs up.
KjcfeF100
« Reply #17 on: May 19, 2020, 02:39:01 PM »
Quote
Good rocker shafts, billet stands with supports, non-adjustable OE rockers with tight shaft clearance.
Who makes those stands / supports?  Are those from P.O.P.?  I don't recall seeing that exact setup.
BigBlueIron
« Reply #18 on: May 19, 2020, 03:24:31 PM »
Highboys are reason I fell into the FE world.  Head over heals
CaptCobrajet
« Reply #19 on: May 19, 2020, 06:26:39 PM »
Shafts and stands from Rocker Arms Unlimited.  He does a nice job on the tips of the old rockers also.  I put the stud kits together with ARP studs,thick washers, and 6-point flanged nuts. I shim outside the end plugs and put a roll pin in there so the end plugs can't ever come out.  All bulletproof stuff for a combo like this.
Someone asked about the trans in the truck.  It is an NV4500 5-speed.  The truck has a twin stick divorced transfer case, so adapting the trans was not that difficult.  Custom clutch, driveshaft, and mount fabrication.
« Last Edit: May 19, 2020, 06:31:07 PM by CaptCobrajet »
Blair Patrick
JamesonRacing
« Reply #20 on: May 19, 2020, 07:16:43 PM »
Blair, you seem to love building the torque monsters more than the high winders!  I'm sure that the all-iron torquer you built for me doesn't make quite the big numbers that this one does, but it gets the towing done quite well regardless.
CaptCobrajet
« Reply #21 on: May 19, 2020, 08:47:45 PM »
I like doing them David......thanks for the compliment.  That one you have is a good piece.  I'm partial to the FE period.  They can be built for any purpose.  I grew up standing on the tunnel of a '66 shortbed shifting the column for my dad when I could barely see over the dash. (May not be the safest thing, but I lived to tell it).  Then a '69 F-250, then a '77 Camper Special 350, as a kid.  We still have two of those three trucks.  I do love the trucks, and I like making them pull when that is the task.
I've towed a lot of miles in all 48 lower states over my life.  Every time I hit a grade, I look at the tach in whatever I'm in, and think of how to make an FE run there.  We need maximum torque from 2200-4000 to tow heavy.  I try to figure out how to maximize that range.  If you happen to turn it more to get a good spot in the next gear, it needs to be up to the task.  Fun stuff for me, just different from an 8000+ rpm race engine.
We ran a Stock Eliminator engine the day before this one.  Sure was a different program.  A DTS has a load adjustment knob on the console.  This 469 wouldn't load at 2500....it was like it was driving through a converter.  We had to crank the load knob almost all the way to pull it down to 2200 to start a low pull.  Kinda funny.....it drew laughs from Jim and me once we figured out how to get the dyno to run it.  We did some steady state and very slow rate pulls to get really good air/fuel data.  We had fun with it.
Blair Patrick
« Reply #22 on: May 20, 2020, 12:02:12 AM »
You can play the load up/down on the DTS a bit by rotating one of the water control cogs a tooth in either direction - I've had to do it a couple times.  Learned the trick from one of the DTS guys several years ago when they were still in business - when we were required to pull a 505 inches down to 2500 for EMC testing.  You can also "overpressure" them a bit if you have a motor controller on the inlet pump.  Doing that will pretty much bring a smaller engine to it's knees if you forget to readjust for the next session...
« Reply #23 on: May 20, 2020, 04:48:51 AM »
I think we all like doing something different now and again.  If you do the same stuff over and over, you don't learn much.
I will say that's why I like dyno'ing where I dyno.  The dyno may be older, but it's a manual valve Stuska, and we can load it until it chokes the engine out.  I've done some similar truck engines and we could successfully pull them down to 2500.  That's a bit lower than we normally start the "spirited" engine pulls.
CaptCobrajet
« Reply #24 on: May 20, 2020, 07:39:16 AM »
Hey Barry, I have heard about moving the one tooth before.  Getting them to load way down low with a lot of torque can require a recipe.
Brent, I have a Stuska with Dpac data, that had been updated before Dave got killed.  We aren't too far from having it running here.  I spent a lot of time and made thousands of pulls on a Stuska/Dpac with manual load many years ago.  When I went looking, that is what I wanted.  We will be able to run automated or manual load.  Hard to beat a Stuska.
Blair Patrick
« Reply #25 on: May 20, 2020, 10:18:38 AM »
Blair - That's a heck of piece you built there  8)  600 ft-lbs all day.  I'm drooling!  Having that in a street-driven full-size Ford would be heaven.
CaptCobrajet
« Reply #26 on: May 20, 2020, 11:00:10 AM »
Thanks Bill!  Means a whole lot coming from a man who has seen and done what you have.  I have been thinking how neat that engine would be in a big car or a power brake Mustang or Fairlane.  It is so smooth idling when warm.  I think in a car I would put the cam on a 112 separation so it would peak about 56-5700.........still would be mean but not having to lug a trailer I think the 112 would be better in a car.  An overdrive manual, or lock-up AOD would be a pup with that low end on tap.  Take care.....
Blair Patrick
« Reply #27 on: May 20, 2020, 11:31:20 AM »
...  An overdrive manual, or lock-up AOD would be a pup with that low end on tap.  Take care.....
I can tell you that at Ford, we spent a ton of development time massaging the low-end torque curve.  Fat and flat brings out the biggest smiles (at least when it comes to engines)  :o
Anybody can throw together a combo that puts up a peak HP number.  That's the guy spinning his wheels in the mud hole.  I'd much rather be the guy who pulls him out while calmly sipping a latte with the A/C on  ;D
I love reading about your stuff Blair.  Hopefully soon I'll be able to show you guys some new stuff I'm working on.  The Covid lockdown has severely limited my time on the CNC...
« Reply #28 on: May 20, 2020, 12:45:06 PM »
Blair, on those high flowing heads, did you use 30 deg seats?
Your low rpm numbers are outstanding!
CaptCobrajet
« Reply #29 on: May 20, 2020, 03:35:53 PM »
Seven angles on the intake valve, and there is a 30 in there, but it isn't the seat.
Two top angles, an .080 wide seat on the exhaust to help carry away the heat, a radius, and another little blend angle on the bottom.
That's all I'll say about the seat work, but safe to say they ain't the average three angle deal, and it makes a large difference.  8)
Blair Patrick
