Author Topic: FE Power 8V Intake  (Read 10542 times)
FE Power 8V Intake
« on: May 16, 2020, 04:41:22 PM »
This is the dual four barrel cast aluminum intake that I will be offering for my cylinder heads.  I just got the first two castings off the CNC machine and got the halves assembled, so I thought I would post some pictures.  This manifold is similar to my 4V intake in that it splits apart for easy porting, if that is desired.  This particular one is drilled for the 4150 Holley carb pattern, but drilled and tapped so that the carbs can be mounted in either direction.  Carb spacing is the same as the factory Ford medium riser or tunnel port spacing, not the larger high riser spacing, so that factory carbs and oval air cleaner bases can be used as-is.  As you can see the manifold also has provisions for EFI injectors, if someone wants to go that route.
The photo below shows one half of the manifold with the O-ring cords installed:
And, here's a picture of how it looks on the intake adapter:
These are the three different cast aluminum intakes that will work with my heads (I also plan a billet, sheet metal style intake, but I haven 't got that designed or machined yet).  That's a pretty nice line up of intakes, if I do say so myself  ;D
I'm really getting anxious to run the heads and these intakes on the dyno.  All I really have left to do is make up a rocker arm setup that incorporates the latest changes, then build the dyno mule and the headers for the RE heads, and run.  Not too much longer, I hope...
feadam
Re: FE Power 8V Intake
« Reply #1 on: May 16, 2020, 05:28:10 PM »
Any pictures of heads fully assembled?
« Reply #2 on: May 16, 2020, 05:35:29 PM »
Out of my league, but looks amazing.  I like that you think of the practical aspects as well as power and beauty.
paulie
« Reply #3 on: May 16, 2020, 06:06:57 PM »
That cross-ram looks as if it'd be just the ticket to fit under the hood of a Cobra Daytona and provide for outboard mounting of a pair of hairdryers. ;)
Where do the injectors go?
« Reply #4 on: May 16, 2020, 06:10:37 PM »
Ha!  I wish.  The heads have been ready for almost two months, but since the end of March I've been waiting for the valvesprings I need to arrive.  Covid shutdown and all that.  Hopefully soon...
« Reply #5 on: May 16, 2020, 06:13:51 PM »
The injectors are mounted horizontally, underneath the runners.  The injectors and vacuum taps are basically hidden.  I don't know if it will fit under the hood of a Cobra or Daytona Coupe, but based on my measurements it will fit under the flat hood of a Mustang or Torino or Fairlane, and probably a Galaxie too, although I haven't measured that...
« Reply #6 on: May 16, 2020, 06:20:05 PM »
I'm mentally picturing something that looks like a header, made of aluminum tubing, on each side. With the collectors properly configured, it would be pretty simple to put a turbo on the end of each of them and have SS headers underneath to bring the exhaust gasses up to the hot side.
Joey120373
« Reply #7 on: May 16, 2020, 07:57:57 PM »
That's just gotta be one of the coolest line up of intake manifolds ever.
Thank you Jay, you just made my whole day better.
« Reply #8 on: May 16, 2020, 08:24:06 PM »
That represents one hell of a lot of work and that’s prolly not even half of your time/money/pain investment.
Congratulations and thanks for advancing the platform.
« Reply #9 on: May 16, 2020, 09:57:05 PM »
Pro Stock Jay strikes again   ;)
Except the availability is far better, as is the customer service.  ;D
Couple questions....
Will a factory distributor fit? Or how about an aftermarket like MSD?
Why does the casting appear so thick on the ends of the plenum, at the bottoms? Is it just a mold issue? Seems like there's a lot of weight that could be eliminated there with some careful handwork, not to mention space for the distributor, if it's close.
Ports look like they could feed some serious horsepower! It'll be interesting to see what they do on the dyno.
Ghoughton
« Reply #10 on: May 17, 2020, 06:05:26 AM »
Lovin the dual four.....nice work Jay
Gaugster
« Reply #11 on: May 17, 2020, 08:27:37 AM »
Great to see things are coming along. I am waiting on car parts too but for the interior rather then engine. So I understand the pain of waiting. Good luck with the build and test!
« Reply #12 on: May 17, 2020, 09:25:53 AM »
Factory or MSD distributors will fit, at least based on the computer model.  The MSD distributor is a little tight, but if it turns out to be a problem I can add a machining operation to clearance the intake a little in the distributor location.
The casting is thick especially down at the bottom as you mentioned, and a little blocky looking.  There's multiple reasons for that.  One reason is that I wanted to leave a lot of room for porting, in the runners and plenum, because I think with some work this intake would support 1000 HP.  Another is that where the intake bolts together you have to have room for the O-ring cord, bolt holes and threaded holes for the bolts, and some 1/4" pin holes and threaded holes for locating and bolting the manifold half to the machining fixture during the last machining operation (see the O-ring cord picture in the original post for some of these items).  The last reason is financial.  I could have sculpted and smoothed the outside of the casting quite a bit to remove weight and streamline it a little, but then the cost of the tooling required to cast the manifold goes way up.  I'm not trying to make a fortune on this project, but I'm not going to do it if it's going to cost me a bunch of money either, and in light of the fact that I've got to tool the castings for the cylinder head and three different intake manifolds, I'm trying to minimize the tooling costs.
I learned a while back that converting a cool part into one that is manufacturable at a reasonable cost is pretty hard to do.  The design of the parts reflects the cost constraints that I'm working under, in order to get the parts to market and not lose my butt on them LOL!
« Reply #13 on: May 17, 2020, 09:41:09 AM »
Wow, that looks terrific Jay! Nice ideas all around  especially the ability to mount the carbs either way. Gee, its too bad Edelbrock and all of it's engineers couldn't have though of the same great idea.
Question: the overall runner length (carb top plane to the face of the port intake at the head junction to looks to be amazingly close to the 351C intakes (Weiand bottom/custom tops) run on the killer Pro Stock engines of yore. What is, roughly, that total length if you don't mind?
« Last Edit: May 17, 2020, 10:19:44 AM by machoneman »
« Reply #14 on: May 17, 2020, 09:57:31 AM »
It's about 8", Bob.  How does that compare to the 351C manifolds you were talking about?
