Author Topic: Still need a 28 spline 9" 3rd member ... 3.50, 3.70 or such  (Read 4029 times)
winr1
The pile of 9" junk keeps getting larger
I could use a 3.50, 3.70 or ??
Prefer it not to have teeth sharp enough to shave with, deep pits in the bearing surface
Howls as the wolfman, been driven cross country with no fluid, been submerged in salt water for years, etc
1/2" backlash and metal shavings packed around the insides
Ricky.
6667fan
  • Every Second Counts
Re: Still need a 28 spline 9" 3rd member ... 3.50, 3.70 or such
« Reply #1 on: May 07, 2020, 06:18:19 AM »
That’s funny stuff Ricky!
What is the ideal unit you are after? 28 spline 4 pin Trac-Loc with 3.50 gears? Do you need a case? I saw a 3.50 gear set here the other day.  I know I don’t have an assembled case with the differential that you are after but maybe a collection of the parts.
JB
jwysocki@charter.net
JB
67 Fairlane 500
482 cid 636/619.
10.55@125.74 1.46 60’
dsarge390
« Reply #2 on: May 07, 2020, 12:17:35 PM »
On FB Marketplace, there is a guy in Melville, NY with a 3.73  limited slip, but You would have to install it in your center section....
plovett
« Reply #3 on: May 07, 2020, 03:57:19 PM »
Where are you located?  I think I have a used 3.75 (not 3.70) geared 28 spline center section with an Auburn limited slip in it.
winr1
« Reply #4 on: May 07, 2020, 07:28:12 PM »
Thanks guys :-)
JB, what all do ya have ??
dsarge390, thanks, I will see if I can find it
Paulie, I live in Texas, close to Galveston Isle
Ricky.
plovett
« Reply #5 on: May 07, 2020, 09:59:15 PM »
Oh, now I see you are looking for just a ring and pinion?
I am in the KC area. A long time ago I used to live in Houston.  I've went to Galveston a lot.
winr1
« Reply #6 on: May 07, 2020, 11:41:44 PM »
Paulie, I would rather have a complete 3rd member that was in good condition
Or perhaps a 3rd member that needs a little work
Would you consider selling/trading yours to me ??
Ricky.
plovett
« Reply #7 on: May 08, 2020, 08:48:49 AM »
I will pull it out of my garage this weekend and take a look at it, Ricky.
winr1
« Reply #8 on: May 09, 2020, 01:37:38 AM »
Thanks much :-)
Ricky.
plovett
« Reply #9 on: May 10, 2020, 09:45:30 AM »
Thanks much :-)
Ricky.
I found it.  Do you want me to send you a picture?  You can PM me if you like.
winr1
« Reply #10 on: May 10, 2020, 12:47:29 PM »
Hey Paulie
You can post a pic here or in a PM.... whichever you wish :-)
Ricky.
plovett
« Reply #11 on: May 10, 2020, 01:02:19 PM »
I don't have a photo website to use.
Tried attaching image......
« Last Edit: May 10, 2020, 01:52:59 PM by plovett »
winr1
« Reply #12 on: May 11, 2020, 10:39:36 AM »
Thank you Paulie
Can you tell me about the 3rd member as to its shape and if you have run it and such please ??
How much you were thinking of asking for it ??
EDIT..... do you know if this a cone or plate LSD ??
Ricky.
« Last Edit: May 11, 2020, 11:02:43 AM by winr1 »
plovett
« Reply #13 on: May 11, 2020, 11:34:57 AM »
Auburn cone. Driven about 5000 miles behind a 520 ft/lb 428 on street tires.  Never had had problem...….except one time....hit it and looked back and saw a one wheel peal.  Maybe I was on an incline or turning slightly, who knows?
Call me (or text) if you want it. 913-954-2854
How about $250 shipped?  It's probably worth twice that?  Just don't tell me about your $15,000 paint job after I send it to you.
« Last Edit: May 11, 2020, 11:41:28 AM by plovett »
winr1
« Reply #14 on: May 12, 2020, 12:27:35 PM »
That sounds like a great deal and thanks !
How do you wish to be payed ??
 ( rattle can flat black paint job )  ;)
Ricky.
« Last Edit: May 12, 2020, 09:12:37 PM by winr1 »
