Author Topic: Cut down plenum divider  (Read 5790 times)
KMcCullah
« on: January 11, 2013, 08:54:14 PM »
I was kicking thru the graphs in the dyno section and found one where Jay built a 492 with a modified Blue Thunder dual plane intake with a removable divider. The HP gain was notable.
Question for Jay: Can you post the associated graph showing the torque curves?
Question for everybody: Has this mod ever been tried with a Performer RPM with a smaller FE on a dyno?
Kevin McCullah
Re: Cut down plenum divider
« Reply #1 on: January 12, 2013, 03:44:17 PM »
Sorry for the delay, it took me a while to dig out this data (from 2005):
KMcCullah
« Reply #2 on: January 12, 2013, 04:51:19 PM »
Thank you Jay! Wow, I was expecting to see a compromise in torque but in this case, the opposite. I hope you do some similar dyno tests when you get your intake and adaptor package running.
Kevin McCullah
hotrodfeguy
« Reply #3 on: January 14, 2013, 09:07:37 PM »
That was some interesting data, Thanks Jay. I also was wondering about tricks to the RPM. And how far the RPM could be tricked out to.
« Reply #4 on: January 14, 2013, 09:17:08 PM »
On my supercharged engine that made 1030 HP, the RPM manifold ports were enlarged to match the CNC ported heads, but no further work was done to it.  The RPM is a really, really good manifold just as it is...
fe66comet
« Reply #5 on: January 15, 2013, 11:26:05 AM »
Hopefully my air gap duel quad RPM will give me similar results. Not sure how much to loose if any or just use a spacer.
