FE Technical Forum
Cut down plenum divider
Topic: Cut down plenum divider (Read 6485 times)
KMcCullah
January 11, 2013, 08:54:14 PM »
I was kicking thru the graphs in the dyno section and found one where Jay built a 492 with a modified Blue Thunder dual plane intake with a removable divider. The HP gain was notable.
Question for Jay: Can you post the associated graph showing the torque curves?
Question for everybody: Has this mod ever been tried with a Performer RPM with a smaller FE on a dyno?
Kevin McCullah
Administrator
Re: Cut down plenum divider
Reply #1 on:
January 12, 2013, 03:44:17 PM »
Sorry for the delay, it took me a while to dig out this data (from 2005):
KMcCullah
Reply #2 on:
January 12, 2013, 04:51:19 PM »
Thank you Jay! Wow, I was expecting to see a compromise in torque but in this case, the opposite. I hope you do some similar dyno tests when you get your intake and adaptor package running.
Kevin McCullah
hotrodfeguy
Full Member
Reply #3 on:
January 14, 2013, 09:07:37 PM »
That was some interesting data, Thanks Jay. I also was wondering about tricks to the RPM. And how far the RPM could be tricked out to.
Administrator
Reply #4 on:
January 14, 2013, 09:17:08 PM »
On my supercharged engine that made 1030 HP, the RPM manifold ports were enlarged to match the CNC ported heads, but no further work was done to it. The RPM is a really, really good manifold just as it is...
fe66comet
Reply #5 on:
January 15, 2013, 11:26:05 AM »
Hopefully my air gap duel quad RPM will give me similar results. Not sure how much to loose if any or just use a spacer.
FE Technical Forum
