Author Topic: 482 going on pump. Guess the HP version 2.0, prize to winner.  (Read 12691 times)
6667fan
  • Every Second Counts
Freshened 482 might get lit off this week. Double your chances to win a guess the hp prize. ( well, not you Brent unless you bid on yours under a pseudonym).
Closest guess to uncorrected peak hp number without going over wins a Walmart gift card.
4.25 x 4.25
Scat steel crank
Scat H-beams
Mahle pistons 9 cc dish 1mm/ 1mm/2mm ring pack, 11.3:1 CR
Barry’s CNC heads from ‘18 EMC, Comp beehives 520/195 spring pressures
Dove tunnel wedge massaged by Les Schmader.
Melling HV pump
Canton 15-850 pan with windage tray, 7 qt system
Innovators West balancer
Erson roller rocker assembly
11/32”, .080 push rods
Lykins custom hydraulic roller, 255/263@.050, 112 LSA, 108 ICL, 625 lift
Morel limited travel lifters
Pair of QFT 715 vacuum secondary carbs
Aluminum water pump
MSD 8595 distributor/ phased rotor/ 8mm Taylors
Shop 1-7/8” headers
Couple caveats: the tunnel wedge ports are a significant mismatch to Barry’s intake ports. 1-3/16” vs 1.75. There is not enough beef around the Dove ports to go any bigger without compromising the ability to seal the intake. It would have taken an aluminum artist and more than I paid for the intake to get the ports larger or invest in a BBM intake.
Gonna run it on some 100 octane.
Big tip: ran this combo a year ago with a worked Victor courtesy of Jay Brown and a QFT 950 hp and it made 632/627 on a numbers friendly Dyno Mite Land and Sea pump using 93 octane.
All are welcome to play.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Re: 482 going on pump. Guess the HP version 2.0, prize to winner.
« Reply #1 on: March 15, 2020, 03:33:31 PM »
649 HP
638 FT lbs
She should haul the mail for sure.
338Raptor
« Reply #2 on: March 15, 2020, 05:08:44 PM »
640 hp
FirstEliminator
« Reply #3 on: March 15, 2020, 05:33:36 PM »
666
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
« Reply #4 on: March 15, 2020, 06:04:57 PM »
651 HP
« Reply #5 on: March 15, 2020, 06:06:17 PM »
Love it’s a square motor.
I like Raptors 640 so I’ll go 5 less at 635.
Marks 666 is funny as hell  ;D
Edit
Fix spelling, damn spellcheck.
Appropriate emoji
« Last Edit: March 16, 2020, 08:04:32 AM by turbohunter »
70tp
« Reply #6 on: March 15, 2020, 07:38:43 PM »
625
cattleFEeder
« Reply #7 on: March 15, 2020, 10:46:19 PM »
630 hp
make the prize a bale of TP
Remember, RPM is your friend
FirstEliminator
« Reply #8 on: March 16, 2020, 12:05:00 AM »
I'm an Iron Maiden fan and figured it's in range to blurt out the number of the beast.
Marks 666 if funny as hell ::)
Mark
68 Monterey 390 C-6
475fetoploader
« Reply #9 on: March 16, 2020, 02:18:47 AM »
643.
1967  519 c.i.  TKX 5 speed
KMcCullah
« Reply #10 on: March 16, 2020, 07:38:11 AM »
642.
Kevin McCullah
« Reply #11 on: March 16, 2020, 08:01:17 AM »
Nice, love ‘em.
Twinibeam66
« Reply #12 on: March 16, 2020, 09:00:55 AM »
639 HP
John67427
« Reply #13 on: March 16, 2020, 09:08:37 AM »
I'm guessing 649...
Glad you got it back together, it will  produce some good power
« Reply #14 on: March 16, 2020, 12:22:14 PM »
999hp... a nitrous bottle left over from a Chevy test will fall over and knock the valve off  spraying into your engine.
If that doesn't happen i'll say 667
