Author Topic: TRW pin locks..  (Read 7082 times)
64PI
TRW pin locks..
« on: March 10, 2020, 11:08:39 AM »
Does anyone have a part# for SpiroLox or clips for TRW pistons? I'm guessing they are factory size locks. I just don't have a set of pistons in front of me to measure the clip groove. Thanks.
Fred
gt350hr
Re: TRW pin locks..
« Reply #1 on: March 10, 2020, 11:24:22 AM »
   Fred,
     You need to be careful as TRW typically used a tru-arc lock that was .052 wide. "Industry standard" is .042 wide , same for spirolocks. Using the wrong lock WILL  create too much end float on the pin and damage the lock or piston and have the pin dragging the wall and potentially break the piston. With TRW being gone, you may have to try and find original Ford locks. Just make sure they measure .052 wide.
   Randy
64PI
Re: TRW pin locks..
« Reply #2 on: March 10, 2020, 02:39:03 PM »
Thanks, Randy. I'll see what I can find.  Finding info on these old pistons is tough.
66FAIRLANE
  • Andy
Re: TRW pin locks..
« Reply #3 on: March 11, 2020, 04:48:30 PM »
I have a set of 2291F sitting around I can measure but I am not home for a few days?
Richard F
Re: TRW pin locks..
« Reply #4 on: March 11, 2020, 07:47:41 PM »
I used spirlox on my TRW's and never had a problem.  I admit though that I never measured them I just ordered what was listed in the parts book.  I still have a set new I can dig out the bix for the part number.
winr1
Some info
« Reply #5 on: March 11, 2020, 08:18:22 PM »
http://www.network54.com/Forum/74182/thread/1484247359/last-1484272404/View+Thread
http://www.opticatonline.com/part/sealed-power-lr-n540098-engine-piston-lock-ring
Use w/H304P,329NP,381P, H395P,993P, H994P, H995P, L2245F, L2291F, L2303NF
 Part Number    LR-N540098
00614046882232
16 each
https://www.amazon.com/Sealed-Power-LRN540098-16-LOCK-RING/dp/B003TQ6JHK
$29.36
http://www.northernautoparts.com/part/vt-lr-n540098
$1.50 each
http://sealedpower.carshopinc.com/product_info.php/products_id/106173/LRN540098-16
$24.95 16
http://www.summitracing.com/parts/slp-lr-n540098/overview/
 Brand: Sealed Power
Manufacturer's Part Number: LR-N540098
 Summit Racing Part Number: SLP-LR-N540098
UPC: 614046882232
Wrist Pin Retainer Type: Wire lock
Wrist Pin Retainer Material: Steel
Wrist Pin Diameter (in): 0.975 in.
Wrist Pin Retainer Thickness (in): 0.050 in.
Wrist Pin Retainer Outside Diameter (in): 1.120 in.
http://www.summitracing.com/parts/ros-4004-e/overview/
 Wrist Pin Retainer Type: Spirolox
Wrist Pin Retainer Thickness (in): 0.042 in.
Wrist Pin Retainer Outside Diameter (in): 1.080 in.
http://www.roushyatesparts.com/parts-p/jep-094-050-ct.htm
    Style: Tru-Arc Lock
    Wire Diameter: 0.05
    Material: Carbon Steel
    Pin Diameter Range: 1.090 - 1.100
https://www.cbperformance.com/ProductDetails.asp?ProductCode=1030
1030 True-Arc Wrist Pin Locks (set of 8)
List Price: $6.95
Our Price: $5.95
You save $1.00!
Product Code: 1030
http://www.gt40s.com/images/howto/LynnMiner/Reference/SAE_Papers.pdf
http://www.ebay.com/itm/Speed-Pro-LR194-16-1-040-in-C-Clip-Speed-Pro-Wrist-Pin-Lock-16-pc-/181910467552?hash=item2a5ab573e0:g:04sAAOSw~bFWKVQ8&vxp=mtr
Speed Pro 1.040 in C-Clip Speed Pro Wrist Pin Lock 16 pc P/N LR194-16
    Wrist Pin Lock
    Speed Pro
    C-Clip
    1.040" Wrist Pin Diameter
    0.042" Thick
    Steel
    Set of 16
http://www.mcmaster.com/#circlips/=zp9g1a
Fits Groove
Ring Size
For Bore
Dia.   Dia.   Width   (A)   Thick.   Pkg.
Qty.       Pkg.
Black-Finish Steel
1/4"   0.268"   0.02"   0.28"   0.015"   50   99142A310   $5.78
5/16"   0.33"   0.02"   0.346"   0.015"   50   99142A320   6.05
3/8"   0.397"   0.029"   0.415"   0.025"   50   99142A330   6.05
7/16"   0.461"   0.029"   0.482"   0.025"   50   99142A340   6.05
29/64"   0.477"   0.029"   0.498"   0.025"   50   99142A345   7.62
1/2"   0.53"   0.039"   0.548"   0.035"   50   99142A350   7.78
9/16"   0.596"   0.039"   0.62"   0.035"   50   99142A360   8.07
5/8"   0.665"   0.039"   0.694"   0.035"   50   99142A370   8.58
11/16"   0.732"   0.039"   0.763"   0.035"   50   99142A380   8.75
3/4"   0.796"   0.039"   0.831"   0.035"   50   99142A390   9.79
0.777"   0.825"   0.046"   0.859"   0.042"   50   99142A400   9.65
13/16"   0.862"   0.046"   0.901"   0.042"   50   99142A410   10.81
7/8"   0.931"   0.046"   0.971"   0.042"   50   99142A420   11.60
0.901"   0.959"   0.046"   1"   0.042"   50   99142A430   11.67
15/16"   1"   0.046"   1.041"   0.042"   25   99142A440   7.81
1"   1.066"   0.046"   1.111"   0.042"   50   99142A450   12.83
1.023"   1.091"   0.046"   1.136"   0.042"   50   99142A460   13
Tru-Arc ---  Circlip
Relaxed diameter
Thickness
Factory 360 used
1.066 -- 1.075
.050 -- 1.051
391 FT.. used
1.075  -- 1.082
.052 -- .053
Unknown
1.055 -- 1.060
.047 -- .050
Forged .. installed, not run
1.080
.052
Speed Pro 390 cast .. never installed
1.101 -- 1.105
.049 -- .051
Number on package 16x98
FT wrist pin 186-187 --  .187 thick
Unknown wrist pin   --.140 thick
Ricky.
67428GT500
Re: TRW pin locks..
« Reply #6 on: March 11, 2020, 11:54:09 PM »
DO NOT USE TRU ARC! Use Spirolocs.  I have seen many come out and destroy cylinder walls.   I have dual Spirolocs in the JE pistons on each side. I had them milled to make removal easier. What a pain in the arse!
gt350hr
Re: TRW pin locks..
« Reply #7 on: March 12, 2020, 10:03:58 AM »
  Keith is correct , True arcs do not like RPM. The "eyelet" breaks off right at the thinnest point. If one falls out , it's because it wasn't installed correctly. Ford has used them forever in the FE and millions survived. The "sharper edge" of the lock MUST be installed facing the outside of the piston , this secures it in the groove. If the rounded edge is installed outward , the lock has a tendency to "jump out". As I cautioned , use of a different width lock WILL cause a failure. End play on a True arc OR Spirolock WILL cause a failure. .010 is MAXIMUM allowable.
   Ford/TRW/Sealed Power FE pistons are designed to use a .050-.052 lock and Winr1 has provided links to obtain them. Continuous operation /drag racing above 7,000 RPM "could" and has caused True arc failure.
      Randy
