Author Topic: I'm baffled! MSD distributor will not drop in?  (Read 9160 times)
fairlaniac
« on: March 09, 2020, 07:54:48 PM »
I have a MSD Pro Billet 8594 that I ran in my 390. So I had the local machine shop install a new steel gear for my new 427 build with roller cam. It will not drop in. It gets hung up on the land and the bottom of the shaft doesn't seem to line up and drop in the pilot hole. Now it will not even drop in the 390 block it once fit? So I try a points distributor I have lying around. It drops in. I mic'd the shaft end and body. Both are exactly the same. I chuck the distributor up and put a dial indicator to it to see if the shaft got bent at the shop. Zero run-out. Thought not the issue I tried a duplicate ARP oil pump shaft in the end. It slides in properly. I measured into the hole and got the dimension from the top of the opening in the block to the land and it measures the same as the point where the distributor stops going in. I'm pretty certain it is hitting the land and just not hitting the hole. Any ideas? This is so freaking basic I cannot believe it won't drop in. I also snap gauged the pilot hole and it is a few thou bigger than the diameter of the shaft. What could be wrong? Only difference as stated a new steel gear installed. it is the same o.d. as the cast gear. I also turn the crank to see if it will drop but it doesn't?
Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: I'm baffled! MSD distributor will not drop in?
« Reply #1 on: March 09, 2020, 08:06:26 PM »
Did you use a distributor to locate the intake manifold? If not, it can be off enough to bind the distributor up, or just stop it from dropping in. That doesn't explain why it won't drop into the old engine though, but it's still something to check. Have you measured and eye-balled the gear to make sure it's the same diameter, tooth size etc? One last thing to check would be the hole size in the intake. I forget what intake you used, but aftermarket parts are always susceptible to machining errors.
fairlaniac
« Reply #2 on: March 09, 2020, 08:09:26 PM »
I shoulda said, the manifold is not on yet. I was making sure the distributor went in before I set the manifold. I also mic'd the diameters of the new and old gear, same.
Doug Bender
1978 F150 2WD 390
Cyclone03
« Reply #3 on: March 09, 2020, 08:44:43 PM »
If the only change was the gear something is wrong there. Pitch,diameter ,upside down?
Lance H
« Reply #4 on: March 09, 2020, 09:01:14 PM »
Gotta be gear did you supply it or did they. Do you have the old one to see.
C6AE
« Reply #5 on: March 10, 2020, 12:23:00 AM »
If you have an old cam, hold the distributor w/gear up and engage it. They are 90° to each other and you may be able to mike the overall distance outside cam gear to outside dist gear? Try it with the both distributors. A problem may become apparent.
fairlaniac
« Reply #6 on: March 10, 2020, 04:46:50 AM »
The 390 is pretty much in tact for another project.
I may just pull the distributor apart, put the gear on the shaft and try to drop it in. With the body off I might better see what is going on?
Doug Bender
1978 F150 2WD 390
fairlaniac
« Reply #7 on: March 10, 2020, 04:48:16 AM »
I supplied the Crane gear per my inquiry in this post. http://fepower.net/simplemachinesforum/index.php?topic=8418.0
Doug Bender
1978 F150 2WD 390
« Reply #8 on: March 10, 2020, 04:49:54 AM »
I've seen guys mushroom the end of the shaft when they pull the old gears off.
Oh, another thing....
I've also seen it where the engine was leaning one way hard enough that the pump drive won't center in the hole and the distributor won't line it up when you try to drop it in.  I've had to take a little screwdriver and see if I can center the shaft in the hole, then drop the distributor in.
« Last Edit: March 10, 2020, 06:13:03 AM by blykins »
fairlaniac
« Reply #9 on: March 10, 2020, 06:48:33 AM »
It doesn't look mushroomed but I did run a file around the edge to make sure.
The end of the shaft isn't going below the top surface of the hole to even catch the oil pump drive.
I think if I pull it apart and put the gear on the shaft and drop it in I'll see where my issue lies. I assume if I pull off the collar and the gear the shaft comes out of the body? No other part should unexpectedly fall out I assume?
This is just freaking weird.
thanks,
Doug Bender
1978 F150 2WD 390
1964Fastback
« Reply #10 on: March 10, 2020, 07:07:55 AM »
Is the shaft too big in diameter, like an FT shaft going into an FE block?
Pat
fairlaniac
« Reply #11 on: March 10, 2020, 07:34:30 AM »
Pat
Same diameter and it will not go back into the block it came out of.
Doug Bender
1978 F150 2WD 390
FordEver
« Reply #12 on: March 10, 2020, 07:37:26 AM »
All off the above possible plus , I had replaced that  push in oil plug with a threaded one, it stuck out too far, removed it ground it down, then dropped in.
fairlaniac
« Reply #13 on: March 10, 2020, 07:50:47 AM »
Solid lifter block. No plug behind distributor.
Thanks!
Doug Bender
1978 F150 2WD 390
« Reply #14 on: March 10, 2020, 09:54:26 AM »
Try putting some machinists dye on the base, gear and shaft. You can try to install it then, twisting the shaft and wiggling the base, pull it back out and see if you can see where the interference is. Just a thought, because it has to be hitting someplace.
