Author Topic: Which is the proper steel gear for MSD 8594 distributor  (Read 8362 times)
fairlaniac
« on: February 25, 2020, 09:41:23 AM »
I need to purchase and install a steel gear on my Pro Billet distributor. I have a roller cam now. What is the p/n and are there any special instructions or best practices to installing the gear?
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Which is the proper steel gear for MSD 8594 distributor
« Reply #1 on: February 25, 2020, 10:42:23 AM »
Crane 52971-1.
Install gear per MSD spec, 3.045-3.050” measured from flange to bottom of gear with endplay removed.
« Reply #2 on: February 25, 2020, 12:31:39 PM »
Hey Brent or anybody I guess. Why does MSD have you drill another hole and not use the existing one?
Should one worry about weakening the shaft in conjunction with hv pump?
I’ve done it in the past and everything is still working but it still is in the back of my mind. I realize I’m answering my own question but it doesn’t make sense to me.
« Reply #3 on: February 25, 2020, 01:04:19 PM »
Because the gears and holes vary that much.   I always turn the gear 90° to the existing hole in the shaft, then drill my hole.   I've never had an issue in all these years.
The gear location is very critical though, so go by the dimension and not the hole locations.
« Reply #4 on: February 25, 2020, 01:12:06 PM »
Ok so the hole placement may vary with the selected gears measurement and measurement to the gear is important not hole location. Ok that’s clear again in my little pea brain. Thanks
pbf777
« Reply #5 on: February 28, 2020, 11:47:09 AM »
     In the O.E.s' (and as in many aftermarket units) original manufacturing process the drilling for the roll-pin was an arbitrary endeavor in placement, therefore provides no specific reference as to the the proper gear placement.
     As far as the just turning of the shaft to pick ones' own drilling, as is most often practiced, we prefer and practice the process of removing the original gear, then with a jig we created, compatible with a drill press, to locate the original path of the previous drilling both in length, rotation and center (as often the hole does not pass thru the center of the shaft), press the gear to the proper position, and then place back in our jig thereby requiring drilling only the gear and engaging the original hole presented thru the shaft.  This preserving the shaft for future gear changes.
     And yes, I have witnessed the shafts breaking at the cross of the otherwise accomplished multiple holes drilled; this in one instance, the shaft separated at the drillings, oil pressure lost, the technician removed the distributor and saw nothing wrong, the entire shaft turn together by hand but under the pump load the separated lower section remain stationary only being located in the gear.
     Scott.
fairlaniac
« Reply #6 on: February 28, 2020, 03:40:45 PM »
So I got the Crane distributor gear today. To drill a new hole I understand the tolerance and to rotate the shaft 90 degrees and drill the new hole. I though the gear would have one hole on one side to use as a starter hole and drill through the shaft and the other side of the gear. However, with a hole on both sides what if I set this up in my vice on the drill press and I'm off half a degree. When I come out the other side I'll have an oblong hole in the gear. I don't have fancy jigs so I'm stuck with the drill press and vice.
Doug Bender
1978 F150 2WD 390
« Reply #7 on: February 28, 2020, 03:45:21 PM »
Send it here, I'll do it for you.
fairlaniac
« Reply #8 on: February 29, 2020, 08:14:17 AM »
Thanks Brent, I'll let you know if I need to send it to you.
Doug Bender
1978 F150 2WD 390
fairlaniac
« Reply #9 on: March 01, 2020, 12:06:35 PM »
Crane 52971-1.
Brent when you mentioned to measure from "flange" I was curious which flange. So I set my caliper and set up the picture to clarify. I assume that is the flange you meant?
Thanks!
Doug Bender
1978 F150 2WD 390
« Reply #10 on: March 01, 2020, 12:57:31 PM »
That's it.
cj428cj
« Reply #11 on: March 02, 2020, 05:36:46 PM »
MSD has finally started selling their pro-billet distributor for the FE with a steel gear already installed.  That should save us a lot of headaches in the future. https://www.holley.com/products/ignition/distributors/ford/pro-billet_distributors/parts/85941
MeanGene
« Reply #12 on: January 23, 2022, 10:11:34 AM »
So, it says "MSD now offers Ford distributors with steel gears for use with hydraulic roller cams." No mention of solid rollers- if this gear is proper for a solid roller, why do they specify hydraulic rollers? Should this not be used with a solid roller?
« Reply #13 on: January 23, 2022, 11:36:08 AM »
All FE roller cams, whether they are hydraulic or solid, are made from steel cam cores.  If it’s a steel core cam, it should get a steel distributor gear.
1968galaxie
« Reply #14 on: January 23, 2022, 04:09:30 PM »
Good to know that FE hydro rollers are not ground with the SADI cast cores.
I recall some BBC and SBC hydro rollers were ground on SADI camshaft cores.
