FE Technical Forum
OEM 427 steel flywheel
Topic: OEM 427 steel flywheel (Read 3353 times)
6667fan
Every Second Counts
January 11, 2020, 09:10:18 PM »
What years/versions of 427s caught steel flywheels?
Thanks,
JB
JB
67 Fairlane 500
482 cid 700/617
TFS Tunnel Wedge, BP BBM Heads, Bullet Custom Solid Roller, Ram adjustable clutch, Jerico 4-spd, Strange third member with Detroit Locker, 35 spline axles, 4.86
10.55@125.74 1.46 60’
6667fan
Every Second Counts
Re: OEM 427 steel flywheel
Reply #1 on:
January 14, 2020, 04:12:17 PM »
Perhaps I imagined them. Did 427s catch a different grade of iron? I have a wheel here with the reliefs around the bolt heads and a relieved area at the very inner of the clutch mounting surface that I though to be a 427 flywheel.
JB
JB
67 Fairlane 500
482 cid 700/617
Dr Mabuse
Full Member
No OEM 427 steel flywheel
Reply #2 on:
January 19, 2020, 11:39:30 PM »
As far as I know, OEM 427 manual trans flywheels were all cast iron.
FE Technical Forum
