Author Topic: Guess the horsepower 428CJ....  (Read 31925 times)
« on: December 24, 2019, 06:26:19 AM »
Taking a couple engines to be dyno'd this Friday.  One of which is kind of a "resto-mod" 428CJ deal for a local Thunderbird build.  Rules are the same for this one:  closest without going over, on *corrected* numbers, will get some free goodies.
*Factory 428 block, 4.140"
*Factory 428 crank, .010"/.010"
*Scat 6.490" rods
*Racetec forged pistons, 1.5/1.5/3mm standard tension ring pack
*Federal Mogul main/rod bearings, rod bearings Calico coated
*One of my custom camshafts, 227/235 @ .050", .600/.612" lift, 112/106 LSA
*Morel hydraulic roller lifters
*9.5:1 compression ratio
*Factory C8OE-N heads, 2.09/1.65 11/32" SI valves, Comp Cams valvetrain, no port work, just good valve job
*Performer RPM intake manifold with plenum divider modifications
*Quick Fuel HR-750 carburetor with choke horn
*Lykins Motorsports non-adjustable roller rockers with POP billet stands, end stands, and spacers
*MSD distributor
*Canton rear sump pickup and pan, Melling standard volume pump
*Edelbrock water pump
Engine has no accessories that will be turning on the dyno.
So, closest on that one without going over with win some free Lykins Motorsports decals.
BONUS:
I'm also taking a 289 that's destined for an ERA Slabside 289 Cobra replica.
Whomever guesses the closest on BOTH engines (this means you have to make a guess for both to be eligible), will win a new set of my rocker arm stand shims that should be arriving next week.
Here's the specs for the 289:
*Factory 289 block, 4.030" bore size
*Factory 289 crankshaft, .010"/.010"
*Scat 5.325" I-beam SBF connecting rods
*Compression ratio is 9.7:1
*One of my custom hydraulic rollers, 219/227 @ .050", 110 LSA, .560"/.560"
*Milodon stock style pan and pickup with extra capacity
*World Products Windsor Jr. cylinder heads, no port work, 1.940"/1.600" valves, Comp Cams valvetrain
*Comp Cams full roller rocker arms
*Blue Thunder "Cobra" dual plane intake
*Holley 650 DP carb
*Factory style distributor, recurved, converted to Pertronix
*This engine will be turning the water pump and alternator with an accessory belt
Have fun and happy guessing!  (And Happy Holidays to everyone!)
« Last Edit: December 24, 2019, 08:46:14 AM by blykins »
DuckRyder
Re: Guess the horsepower 428CJ....
« Reply #1 on: December 24, 2019, 06:42:04 AM »
410
281
 8)
Those are some nice looking engines for sure.
Robert
410bruce
« Reply #2 on: December 24, 2019, 06:51:17 AM »
428--422
289--315
« Last Edit: December 24, 2019, 06:56:47 AM by 410bruce »
John 3:16
price5113
« Reply #3 on: December 24, 2019, 07:36:04 AM »
428-455hp        289-340hp
mn67
« Reply #4 on: December 24, 2019, 08:01:00 AM »
428- 470
289- 317
1971 Maverick Grabber
« Reply #5 on: December 24, 2019, 08:14:12 AM »
CJ - 457 HP
SBF - 364 HP
6667fan
  • Every Second Counts
« Reply #6 on: December 24, 2019, 08:53:09 AM »
CJ 456 peak hp
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
jwrmach1
« Reply #7 on: December 24, 2019, 09:29:14 AM »
440 Hp - 428
352 Hp - 289
JWR
shady
« Reply #8 on: December 24, 2019, 10:45:00 AM »
BB-468
SB-368
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #9 on: December 24, 2019, 11:16:40 AM »
444 on the 428.
369 on the 289
gregb
« Reply #10 on: December 24, 2019, 11:34:10 AM »
428  -  430HP
289  -  325HP
DuckRyder
« Reply #11 on: December 24, 2019, 11:41:57 AM »
Boy, I musta missed something on the Windsor because folks are thinking that thing is a real hero...
Robert
« Reply #12 on: December 24, 2019, 11:52:35 AM »
The SBF has decent cylinder heads.  Windsor Jr's.
« Reply #13 on: December 24, 2019, 12:48:00 PM »
410 hp for the 428
330 hp for the 289
427LX
« Reply #14 on: December 24, 2019, 01:04:51 PM »
415 for 428
300 for 289
