Author Topic: Guess the horsepower 428CJ....  (Read 31926 times)
70bosscat
Re: Guess the horsepower 428CJ....
« Reply #30 on: December 25, 2019, 09:37:34 PM »
FE  466
SBF  363
stubbie
« Reply #31 on: December 26, 2019, 07:09:20 AM »
FE 420
375
FirstEliminator
« Reply #32 on: December 26, 2019, 09:28:48 AM »
398 and 246
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
« Reply #33 on: December 26, 2019, 11:52:31 AM »
428 @ 437 hp, 289 @ 370 hp  Joe-JDC
« Reply #34 on: December 26, 2019, 01:51:28 PM »
Had a little scheduling setback, will have to wait until after the weekend.
« Reply #35 on: December 26, 2019, 04:58:09 PM »
398 and 246
Not real optimistic! 246?  Did all of us except Mark miss the 2V carb part or something?
« Last Edit: December 26, 2019, 07:55:42 PM by TomP »
mike7570
« Reply #36 on: December 26, 2019, 05:30:36 PM »
428 - 445hp
289 - 366hp
food for thought - a buddy of mine's 302 pump gas motor very similar to Brent's 289 with Edlebrock heads. 11.70's at street car weight (about 370 hp)
« Last Edit: December 26, 2019, 05:42:52 PM by mike7570 »
mike7570
« Reply #37 on: December 26, 2019, 05:34:27 PM »
moved up to 383w with AFR heads 10.70's. still pump gas but about 100 more hp.
FirstEliminator
« Reply #38 on: December 26, 2019, 08:48:05 PM »
 Who gets the closest without going over?  Doesn't seem like enough cam to go over 1hp per cube. Eh, what do I know?  "Under promise, over deliver" is a good strategy.
398 and 246
Mark
68 Monterey 390 C-6
BBFORDFAN
« Reply #39 on: December 27, 2019, 04:22:59 AM »
466hp for the fe and 355 for the 289
« Reply #40 on: December 30, 2019, 11:38:02 AM »
I'm hoping the 428 falls around 460-470hp. We have a 428 in the shop ready to go together that's almost exactly the same, dang near the same cam specs too. Only difference is it will have BBM heads. With ours I was wishing it would make 490-500. If yours makes 460-470 then I'll be optimistic about the one here.
« Reply #41 on: December 30, 2019, 06:57:20 PM »
Mike, the BBM heads are 30-40 cfm over the factory CJ heads.
If you'll look back through my dyno results on this forum, you'll see two CJ engines with very similar camshafts.  They both made 420-425 hp.  This one made 434 with the Performer RPM intake, but it was knocking on 500 lb-ft of torque.
« Reply #42 on: December 30, 2019, 07:04:06 PM »
Ok, so a frustrating day at the dyno.  The 289's distributor decided to roll smoke out from under the distributor cap because a Pertronix module died right off the bat.  Then the distributor cap had the terminals so far down that two of the plug wires wouldn't reach and I had two dead cylinders.  Fun stuff.  That's why we dyno.
The 428 went perfectly and basically fell in line with the horsepower that my factory-ish 428's usually make.  This one made quite a bit more torque though.
The 289 made 309 hp @ 5750 with 316 lb-ft of torque.
That build should have been built with Dart Iron Eagle heads, which usually flow around the 270-280 mark.  However, Dart is redesigning their IE heads and kept pushing back the release date.   My customer finally told me to pop some World heads on and let's go.  Obviously they are a little better than factory, but they are not Dart heads....
The 428 made 435 hp @ 5250 and 482 lb-ft of torque.  I think we had a couple of 490 lb-ft pulls, but we ended up tuning and catching a little more horsepower.
Who are the winners?
« Reply #43 on: December 30, 2019, 07:18:05 PM »
Nice work Brent. The FE did what I thought it would do but the 289, I thought with the cylinder heads and a better cam it would make more than a stock 289 K code. I could be wrong but didn’t they make 306 HP. I know one of them made 271 HP right.
« Reply #44 on: December 30, 2019, 07:23:00 PM »
The Shelby engine made 306 k engine made 271
