Author Topic: 1966 Ford 352 2bbl, "Original" "Patina" Project Junky Junk Iterations 1, 2, 3  (Read 16400 times)
Performance Summary:
      Cubic Inches:  352             Dyno brand:  Stuska
      Power Adder:   I wish            Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  See Below
      Peak Torque:  See Below
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  FoMoCo C6ME-A, virgin block
   Crankshaft brand, cast or forged, stroke, journal size:  FoMoCo cast 352 crankshaft, standard/standard
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  FoMoCo 352 skinny rods, standard
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  FoMoCo, unknown specifics, virgin slugs
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  FoMoCo
   Piston rings brand, size, other notes:  FoMoCo
   Oil Pump, pickup, and drive:  FoMoCo
   Oil pan, windage tray, oil filter adapter:  FoMoCo passenger car pan, no tray, truck filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  FoMoCo, HFT, roughly 186°, 114 LSA, .400"
   Lifters brand, type:  FoMoCo  HFT
   Timing chain and timing cover:  FoMoCo timing cover, unknown replacement single row chain
   Cylinder heads brand, material, port and chamber information:  C6AE-R, original
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  Factory FoMoCo
   Exhaust valve brand, head size, stem size:  Factory FoMoCo
   Valve springs brand, part number, specs:   Factory FoMoCo
   Retainers and locks brand, part number, specs:  Factory FoMoCo
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory FoMoCo, non-adjustable
   Rocker shafts and stands, brand, material:   Factory FoMoCo
   Pushrods brand, type, length:   Factory FoMoCo
   Valve covers, brand, type:   Factory FoMoCo
   Distributor brand, advance curve information:  MSD billet distributor, quick springs, all in by 2200
   Harmonic balancer brand:   Factory FoMoCo
   Water pump brand, type (mechanical or electric):   Factory FoMoCo
   Intake manifold brand, material, porting information:  See below
   Carburetor(s) brand, type:  See below
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
ITERATION # 1:
Autolite 2100, 356 cfm, 42° total timing:  208 hp @ 4250, 300 lb-ft @ 3250
ITERATION # 2:
Holley 500 2-bbl, 42° total timing, 234 hp @ 4250, 300 lb-ft @ 3750
ITERATION #3:
Blue Thunder 1x4 LR intake, plenum divider cut WAY down, Holley 650 DP, 42° total timing:  264 hp @ 4250, 344 lb-ft @ 3750
Fun day!  Took Dawn dishwashing soap and an extended hot water wash to get the J-squared stink off my clothes :)
BTW, I think there was plenty more in that old girl.  A set of valve springs with some spring and one piece retainers, I bet we would have got 20 more. No BS, that is unless the top rings all broke from hitting the ridge ;)
« Last Edit: November 17, 2019, 01:51:50 PM by My427stang »
You going to flow test the heads the way they come off before you modify them?
I'm debating on what to do, but starting to come around to a less expensive project, using the factory heads with good valves and a good valve job.  If I do use them, I will flow before/after.
No matter what, 44ft lbs with an intake/headers/carb swap is pretty nice.  Totally doable by just about anyone with minimal funding.
Ross, you think that stink is bad?  You should smell the ultrasonic water from my last carb (the burnt one).  man.... I dunno if a shower will get rid of this.
It’s interesting that it made the exact same horsepower in iteration 1 as the Ford advertised gross rating. It’s interesting too that the 1966 Ford Pickup brochure shows a black & gold engine.
We were seeing the net numbers for sure before any tuning.   The gross numbers came with a little bit of work.
Not sure about the color, but it appears that it's been this color all its life.  Who knows.
Were all 66 engines black/gold?  Or just truck?
1966 was the crossover year for blue engines.  All the HP engines were black with gold or black with chrome valve covers until the change over to the blue.  Joe-JDC
Remember these views because the next iteration will look quite a bit different.
MeanGene
Once a bilge rat,...
I'm still surprised a bit at the low gross HP rating even from Ford. Didn't know it was that low as well as the torque. Woulda' guessed even back then it was closer to 250-260 HP. No wonder dad's 1965 station wagon was such a dog, even when brand spankin' new.
And yes, the pickup from the swaps was mighty impressive. Made me remember on Buzzy's near new 327 1967 Camaro (sorry) when we swapped in a hotter cam, aluminum intake and 4-bbl Holley (had headers already) it made a world of difference.
WerbyFord
Great stuff!
The 352's I remember had pure flattop pistons - no valve reliefs. With the huge deck clearance and .400 lift cam they didn't need it.
I thought the valve reliefs came with the "high lift" cam, .430 lift or so instead of .400, in 1966 for cars, maybe 1967 for trucks.
Brent, can you check the cam lobe lift when you pull it out?
No need to really "degree" it, although I would do that even before pulling the chain off.
Just the lift will tell us which cam it is, either .400 or .430 lift, probably worn a little anyway.
On the colors, I have quite a few calendar-1965 ads for 1966 FoMoCo engines- none of the iron is Ford Blue, it's all still black.
Apparently the actual 1966 Model-Year CARS were all Ford Blue. Not sure about the trucks.
In general, the Gonkulator comes in a couple percent higher than these dyno runs, but it cant match that huge 344 ftlb from the BT intake. Must be a special BT 352-High-Torque intake, or maybe JDC ported it?
Gonkulator, with .050 deck, c6ae-r heads, and without water pump drive:
Stock 2bbl
Torq 307 at 2500
Powr 210 at 4100
With 500 Holley
Torq 311 at 2600
Powr 236 at 4500
With BT CJ Intake (is that what it was?) and 650 Holley
Torq 323 at 2900
Powr 272 at 4900
I forgot those valve springs don't even have a damper, so if old and tired no wonder they wouldn't rev high enough.
I’ll degree the cam and check lobe lift when it comes out.
Didn’t degree, but checked lobe lift real quick.  Took 30 seconds to check and 5 minutes to clean the sludge off and apologize to my dial indicator.
.2285” lobe lift.
