Author Topic: 1966 Ford 352 2bbl, "Original" "Patina" Project Junky Junk Iterations 1, 2, 3  (Read 16401 times)
WerbyFord
Didn’t degree, but checked lobe lift real quick.  Took 30 seconds to check and 5 minutes to clean the sludge off and apologize to my dial indicator.
.2285” lobe lift.
Thanks Brent.
.2285 x 1.73 = .395 valve lift so I'd guess the old 1959-1965 .400 lift vanilla cam, 186-186 duration.
Unless that lobe was really worn.
My apologies to your dial indicator.
TimeWarpF100
We were seeing the net numbers for sure before any tuning.   The gross numbers came with a little bit of work.
Not sure about the color, but it appears that it's been this color all its life.  Who knows.
Were all 66 engines black/gold?  Or just truck?
Very Cool!
ALL 1965 Truck 352's Were black with gold valve covers
ALL 1966 Truck 352's Were Corporate Blue
The 1965/1966  Brochures used same pics.
I currently have 7 1966 F100/250 Trucks. Starting with first couple weeks in production to last couple weeks in production. All were Corporate Blue and at least 4 of those had never been apart prior.  I had a mid year 1965 F250 and it was black with gold covers.
I also had a 1966 F600 361 with only 5k miles and it was corporate Blue.
I have checked actual compression ratio on multiple 352's and they were all under 8.0 comp
« Last Edit: November 26, 2019, 10:15:18 PM by TimeWarpF100 »
Will be posting any new info to the thread in the Members' Project section.
