Author Topic: EMC hp guess version 3  (Read 7776 times)
CaptCobrajet
« on: September 26, 2019, 02:06:16 PM »
Mine is .575 lift also, after lash.  Same rules as Joe and Barry.  Mine is a .046 overbore 390, 3.79 stroke, and I used C4AE-G heads.  Works out to right at 400 cubes.  (mbrunson you can't guess in this game!)
« Last Edit: September 26, 2019, 02:09:35 PM by CaptCobrajet »
Blair Patrick
Russ67Scode
Re: EMC hp guess version 3
« Reply #1 on: September 26, 2019, 02:43:08 PM »
535 hp
shady
« Reply #2 on: September 26, 2019, 03:52:14 PM »
482
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #3 on: September 26, 2019, 05:25:43 PM »
I’ll say 538 HP 540 torque
« Last Edit: September 27, 2019, 12:24:31 PM by Stangman »
fastback 427
« Reply #4 on: September 26, 2019, 07:26:55 PM »
575, same as the cam lift.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #5 on: September 26, 2019, 08:12:25 PM »
I was going to guess the same, maybe even 580, but, even though I've attended the EMC event a few times, I don't know how much the "average HP/TQ" rule will affect his peak numbers in competition trim. I'm still going to guess 565 peak HP, just because. If it wasn't an "average" competition, I'd be guessing 580+....with OEM iron.
« Reply #6 on: September 26, 2019, 09:33:17 PM »
Hard to guess without knowing intake, and carburetion, and camshaft specs.  The 10.5:1 compression and passenger car headers, oil pan, and belt driven water pump are all players in the final numbers.  Good luck.  Joe-JDC
« Reply #7 on: September 27, 2019, 05:38:10 AM »
Right in the middle of the Barry/Blair fence with a leg on each side...
Same guess...545 HP / 530 TQ
Jim Comet
« Reply #8 on: September 27, 2019, 12:08:00 PM »
I'll go 555hp/525tq. Jim
mike7570
« Reply #9 on: September 27, 2019, 07:37:02 PM »
I have some interest in this one since it is similar to a stock eliminator build except with more lift, larger valves, porting and a larger carb.
Since I know Blair can build a 1.00sec under (or better) 390 I looked up the F/SA and E/SA index at 1.00sec under and using a Wallace calculator at a 67 Fairlane weight a run that fast would require about 547 flywheel HP +-.  So if I add for the porting and cam lift +30hp, a little larger valve +15hp, and larger carb +10hp my wild ass guess is 602hp.
By the way are we guessing peak or average?  602hp is peak.
I thought about it some more and I think CJShaker is right regarding moving the peak down to pick up a better average over the 3000 rpm range for scoring. So with the peak moved down I’m revising my number -20 to 582hp.
« Last Edit: September 28, 2019, 09:30:26 PM by mike7570 »
« Reply #10 on: October 13, 2019, 01:38:14 AM »
Did Mike win this contest? I think the EMC 390 engine was the grand prize?
CaptCobrajet
« Reply #11 on: October 13, 2019, 10:21:17 AM »
Hey Tom, I think that may be Fake News!  Mr. Mike did have the close number..........I think the best I can do is give him a bit of a discount on a project we are involved in. ;D
Blair Patrick
mike7570
« Reply #12 on: October 13, 2019, 05:01:07 PM »
mike7570
« Reply #13 on: October 13, 2019, 05:09:52 PM »
« Last Edit: October 13, 2019, 05:11:33 PM by mike7570 »
mike7570
« Reply #14 on: October 13, 2019, 05:12:29 PM »
Nothing showing up?
Sorry guys I couldn’t figure out how to delete the empty post above.
I wanted to say I would take that 390 , but I don’t think it would pass tech!
i’m Working on a 428 stock eliminator build and Blair is supplying me with parts and lots of invaluable advice.
« Last Edit: October 13, 2019, 05:29:06 PM by mike7570 »
