Author Topic: Straight thermostat housing for FE?  (Read 7207 times)
falcongeorge
« on: September 04, 2019, 08:25:28 PM »
Does anyone know of a straight thermostat housing that will bolt to an FE intake? It doesn't need a thermostat, I just need one to hook up the return rad hose. The standard 90 degree one causes all KINDS of clearance issues for what I am doing. A 351C one is too small, I already tried that. I can make one, but its a lot of hassle if theres something out there that I am not aware of that would just bolt up.
Dumpling
Re: Straight thermostat housing for FE?
« Reply #2 on: September 05, 2019, 05:20:46 PM »
There should be one available for a remote thermostat...Weiand?
edit: something like this.....they show up on eBay....
https://www.summitracing.com/parts/wnd-7134p?seid=srese1&gclid=Cj0KCQjw5MLrBRClARIsAPG0WGy62obyzDoUJmQGi_OfGjg0cAfCRMp_I11ta3A5xZy32QWtLR652s4aApY-EALw_wcB
« Last Edit: September 05, 2019, 05:23:30 PM by Dumpling »
Dumpling
« Reply #4 on: September 05, 2019, 05:48:26 PM »
How hard would it be to mill off the base of an FE thermostat housing and then weld a straight tube to it?
falcongeorge
« Reply #5 on: September 05, 2019, 06:16:23 PM »
That's probably what I will end up doing, either that or just fabricating one from scratch out of aluminum. But I thought I would try to find a bolt-on solution first.
falcongeorge
« Reply #6 on: September 12, 2019, 10:44:01 AM »
I think the stock 90 degree neck will work, I was worried about clearance around the idler, but its far enough forward to run the upper hose behind the belt.
« Reply #7 on: September 12, 2019, 01:30:46 PM »
An old 292/312 Y Block for Thunderbird will fit, but they are hard to come by, and pricey if you find them.  Mummert in CA has new ones in aluminum for about $65.00 if memory is correct.  Joe-JDC
falcongeorge
« Reply #8 on: September 12, 2019, 01:37:08 PM »
Good to know Joe, thanks. If things don't work out with the 90 degree neck, I will get a Y-block neck.
« Reply #9 on: September 12, 2019, 03:43:53 PM »
  If the housing is corroded any, it will not seal properly.  But it can be made to work as you said you don't need a thermostat.  A thermostat will not work.  Joe-JDC
Kirk Morgan
« Reply #10 on: September 12, 2019, 05:13:38 PM »
I think a big block Mopar will work if you elongate the holes slightly.
Kirk
falcongeorge
« Reply #11 on: September 12, 2019, 05:14:55 PM »
Kirk
Ha! Never even thought of checking that, I have scads of those around!
